AEC software solutions for BIM Management
BIM Management System
The integrated system of applications and functions to manage the digitization of buildings and infrastructures in an easy, secure, shared and collaborative way.
Common Data Environment
The Common Data Environment to manage information and procedures in a single data sharing environment (CDE). Navigable BIM model (freeMDD), control of each step (GATE).
freeware
BIM viewer and more
The free IFC file viewer with which you open, edit, convert and export in the IFC format also AutoCAD® 3D model files (dwg viewer), SketchUp® (skp viewer) and also write IFC parameters.
BIM Clash Detection
The BIM Clash Detection software for checking BIM element interferences and conflicts management between different IFC openBIM models.
Advanced IFC openBIM editor
The application to work on the geometry and properties of a BIM model directly in the IFC format.
IFC Checker and BIM Validation
The application to control and manage IFC data for each information exchange of the BIM process.
Facility management
The Visual Facility Management software that allows you to see your assets and maintenance interventions using 2D/3D maps and models automatically.
Engineering document management
The application to organize, consult and share digital documents on cloud from scratch or using available templates (transmittals, constructions sites, etc.).
Construction management software
The application to manage all the problems that arise in every phase of the construction project, respect the deadlines, ensure the satisfaction of customers and team members.
Geospatial Digital Twin
The solution to create and manage Geospatial Digital Twins of your projects by integrating GIS data with openBIM IFC models.
