How to download and install the software Full and unlimited versions for a free 30-day trial. How to download ACCA software solutions for a 30-day trial period. To download and use the software for free for 30 days, simply follow these easy steps: Access accasoftware.com/en/download Click on the software of choice to use for free. Accept the software terms and conditions of use Check the Notice on the right-hand side and whether your PC has the minimum HW requirements for installing the software. Click "Download Trial version". Log in with your ACCA account e-mail address and password or create one. Confirm the download process. Complete the download How to install an ACCA software solution for a 30 day trial. Once the chosen setup file is correctly downloaded, proceed to installing the 30-day trial as follows: Double click on the downloaded setup file (bottom left corner of the browser bar or default download folder) Choose your preferred install path or accept the proposed default folder. Press the "install" button Wait for the install process to finish. Restart your pc when prompted. Now launch the software by clicking on the program’s desktop icon or from the ACCA folder under Windows Programs. Login to the software with your ACCA account e-mail address and password to activate the free 30-day use period. Please remember that: You can use ACCA software trial versions freely for 30 days. You can subscribe at any time during the free use period directly from the software or from the ACCA e-commerce online store. FAQs Is a subscription plan activated automatically at the end of the free use period? No, software subscription plans are only activated when the user decides to purchase a subscription plan and are never activated automatically at the end of the free 30-day trial period or after installation. Can I transfer and use a free trial software on another PC with the same account? No, you cannot use the same account to run a free software trial on another PC or activate a new trial with another ACCA account on the same PC. If the software doesn’t start, is there anything I can do before contacting ACCA support services? Yes, you can certainly try launching the software as "administrator". Simply do a right mouse button click on the program icon and select “Run as Administrator” from the pop-up menu. How to uninstall the software Access the "Control Panel" Access the "Programs and Features" folder Select the program to uninstall Press the right mouse button and select the uninstall option from the local menu I need to install ACCA software solutions on 150 PCs. How can I perform a "silent install" in unattended mode? Our software setup procedure allows you to use a specific parameter once you have downloaded the installation package. Network Admins can follow this simple guide to install any of our BIM solutions on multiple PCs. First of all download the setup package here (we're considering usBIM.Viewer+ in this case but it's valid for any ACCA software solution): www.accasoftware.com/freeware/usBIM-viewer+ Then, instead of launching the setup directly, click on the: "Do you want to create a setup Package for a different PC", option. This will dump the entire setup package in the default folder: C:\ACCA\SETUP\usBIM.viewer+ Now run the install process using the "-SILENTMODE" parameter in the "RUN" (Windows key+"R") dialogue as follows: C:\ACCA\SETUP\usBIM.viewer+\Setup.exe -SILENTMODE the Installations will launch but default install path and settings will be used: C:\ACCA\usBIM.viewer+ You'll notice that there's no need to assist the install process and once completed, the software will be ready for you to use with a double-click on the relating program desktop icon.
