Engineering document management software
Engineering document management system software free | usBIM.dossier | ACCA software
Looking for an easy way to create, organize, consult and share all the documents of your AEC projects?
Don't waste time searching through piles of files, usBIM.dossier is the solution for you!
Store all your documents in one centralized location with full access to numerous templates to create digital dossiers quickly and easily.
Use it for free Check out the offer
usBIM.dossier is an integrated application in usBIM. Try it for free for a month;
then choose the subscription plan that suits you best from the system store.
Free engineering document management software for a month | usBIM.dossier | ACCA software
You know how it can become difficult to keep the entire set of documents related to an AEC project under control, often causing time wastages, project delays and increases in project management costs due to low efficiency.
With the engineering document management software usBIM.dossier, you can now create, organize and share every type of file, while eliminating the use of paper!
Video Engineering document management | usBIM.dossier | ACCA software
With usBIM.dossier, AEC project document management is no longer a problem!
Save time and money | usBIM.dossier | ACCA software
Save time and money
Eliminate all errors due to poor document management. You have dedicated cloud space to store and organize all your design documents in an organised manner
Simplify access to your dossier files | usBIM.dossier | ACCA software
Digital dossiers are stored directly in the cloud. Get hold of your documents from anywhere and at any time, quickly and securely
Speed up document creation | usBIM.dossier | ACCA software
You have numerous templates that help you create digital files for any type of activity: projects, construction sites, engineering orders, work files, transmittals, etc.
What is engineering document management?
Engineering document management is the process of organizing and storing engineering documents (CAD files, drawings, projects, technical documents and communication documents) so that they can be easily accessible to everyone involved in a given project. Effective management of engineering documents is essential to maintain data accuracy and integrity and can also help improve workflows and productivity.
Engineering document management software can be used to automate various aspects of the process, such as document creation, archiving and retrieval, helping to improve efficiency and reduce costs.
Why does the AEC sector need an engineering document management system (EDMS)?
Delivering projects on time and within budget is one of the main challenges facing the AEC sector.
In order to do this efficiently, we need to have a powerful and well-organized engineering document management system (EDMS).
An EDMS can help companies keep track of project documents, manage version control, and ensure that all team members have access to the latest versions of drawings and specifications, and can also be used to store other information such as contact details, meeting minutes, and progress reports.
What kind of document do you need to draw up?
Create digital files for any type of activity thanks to the numerous templates available with usBIM.dossier
Construction document management | usBIM.dossier | ACCA software
Building Passport
Transmittals | usBIM.dossier | ACCA software
Transmittals
Create your digital file and access all the project documents that you need at any time | usBIM.dossier | ACCA software
usBIM.dossier is a document management system for engineering, architecture and construction projects completely in the cloud that allows you to store and organise all documentation resorces correctly:
  • manage and store documents of engineering contracts, site documents or transmittals in a single centralized location;
  • find and access all the documentation you need from any device without wasting time searching through stacks of documents;
  • track changes to documents and view the latest versions.
Use it for free
Document management system for engineering projects free for a month
A new way to simplify communication and improve project documents management | usBIM.dossier | ACCA software
The documentation of any AEC project must be managed properly to avoid penalties and costly setbacks. It is necessary to ensure that all documentation is easily accessible and can be shared with all involved stakeholders.
usBIM.dossier is the best engineering document management software to simplify communication, make approval processes leaner ensuring that document management is conducted as efficiently as possible!
You can:
  • share documents without the risk that they will be lost, modified or deleted;
  • set custom alerts for document deadlines and reduce the possibility of incurring penalties;
  • share documents with your collaborators with the utmost security;
  • manage authorisation levels and get your documents signed digitally.
Use it for free
Engineering document management system software free for a month
Create any type of document in minutes with the usBIM.dossier templates | usBIM.dossier | ACCA software
Creating the various types of documents for an engineering, architectural or construction project can be difficult; every document has its own peculiarities and essential elements. usBIM.dossier is the essential tool for all document management needs.
Speed up the project document creation process thanks to the wide variety of templates that help you draft:
  • Construction document management;
  • Building Passport;
  • Transmittals.
Use it for free
Use one of the best engineering document management system free for a month
One of the best engineering document management software | usBIM.dossier | ACCA software
Leverage integration with usBIM, the openBIM collaborative platform that accompanies the digital transition of your business
usBIM.dossier is part of the usBIM ecosystem.
Learn more
The usBIM applications
BlogLatest News
Sign in now for free
