BIM Management for Construction Projects
BIM integrated system | usBIM | ACCA software
The largest BIM management system to create and manage models, information and procedures in open and usable formats from the web.
AEC software solutions for BIM Management
BIM Management System
The integrated system of applications and functions to manage the digitization of buildings and infrastructures in an easy, secure, shared and collaborative way.
usBIM.platform | ACCA software
Common Data Environment
The Common Data Environment to manage information and procedures in a single data sharing environment (CDE). Navigable BIM model (freeMDD), control of each step (GATE).
freeware
usBIM.viewer+ | ACCA software
BIM viewer and more
The free IFC file viewer with which you open, edit, convert and export in the IFC format also AutoCAD® 3D model files (dwg viewer), SketchUp® (skp viewer) and also write IFC parameters.
usBIM.clash
BIM Clash Detection
The BIM Clash Detection software for checking BIM element interferences and conflicts management between different IFC openBIM models.
Available for PC Desktop Online integrated application of usBIM
usBIM.editor | ACCA software
Advanced IFC openBIM editor
The application to work on the geometry and properties of a BIM model directly in the IFC format.
usBIM.checker | ACCA software
IFC Checker and BIM Validation
The application to control and manage IFC data for each information exchange of the BIM process.
usBIM.maint
Facility management
The Visual Facility Management software that allows you to see your assets and maintenance interventions using 2D/3D maps and models automatically.
usBIM.dossier | ACCA software
Engineering document management
The application to organize, consult and share digital documents on cloud from scratch or using available templates (transmittals, constructions sites, etc.).
usBIM.resolver | ACCA software
Construction management software
The application to manage all the problems that arise in every phase of the construction project, respect the deadlines, ensure the satisfaction of customers and team members.
usBIM.planAI
2D to 3D/BIM
The application to obtain the BIM model in IFC format of a building starting from scanned and PDF drawings. From paper to BIM quickly and easily, with the help of Artificial Intelligence.
usBIM.geotwin
Geospatial Digital Twin
The solution to create and manage Geospatial Digital Twins of your projects by integrating GIS data with openBIM IFC models.
