3D input to model the scaffolding based on any construction requirement and all kinds of structures
CerTus SCAFFOLDING is the scaffold designer BIM authoring software.
With CerTus SCAFFOLDING you have an advanced 3D input and a catalogue of BIM objects to design the scaffolding that you have in mind with maximum design freedom, without any limits and without the risk of neglecting particular design aspects, with an attention to detail unimaginable until now.
You can design scaffolding suitable for all construction needs and for all types of structures (small and large buildings, civil and industrial buildings, support and road works, etc.), but also scaffolding to support the construction or maintenance of plants and technical systems installed within a building.
You can draw the elements of the scaffolding in plan or directly in 3D view by selecting the characteristics of the objects at any time during the design phase.
Once the type of scaffolding has been chosen (prefabricated with an H-frame or with a portal frame, multidirectional, with tubes and couplers, with prefabricated and mixed uprights and cross-beams), simply position it along the building's perimeter to obtain, in a single input phase, a complete standard scaffolding type, which can be freely customized with all the specific 3D objects available in the catalogue.
The integrated input allows the scaffolding designer to insert, modify and delete objects during the entire design phase, keeping the structure's site plans, cross-sections or axonometric views constantly under control; a powerful diagnostics feature alerts you with any inconsistencies, omissions or errors and guides you through to the resolution of the problem.
Use it for free
Scaffolding design software free download
