Thermal Bridge definition
With TerMus BRIDGE you can define any kind of Thermal Bridge with graphical objects that contain all the relevant data and properties necessary for numerical calculation allowing you to manually input materials and boundary characteristics.
You can import construction details in DXF/DWG CAD file format to quickly draw a thermal bridge of any shape and form. Zoom, SNAP, radial or rectangular grids give extra drawing guidance.
If your Thermal Bridge is among the standard configuration models, you can easily select it from the archive (EN ISO 14863), and customize its thermal and geometric data to quickly generate the calculation model.
TerMus BRIDGE is integrated with TerMus PLUS, the ACCA dynamic energy analysis and simulation software.
Thanks to the live connection between the two solutions you can acquire the materials data inserted TerMus PLUS in TerMus BRIDGE.
Use it for free
Try the Psi calculation software for free for a month.
