Steel connection design software
Design software for structural steel connections | NeXus | ACCA software
Available Soon
Revolutionize Steel Connection Design: Harness the Power of Parametric 3D/BIM Software with Integrated FEM Analysis.
With NeXus, design 3D steel connections without any limits in terms of shapes and loads, view the elastoplastic analysis results in real-time. Unprecedented dynamism, power, and control!
Ask for more info
Steel nodes verification software | NeXus | ACCA software
NeXus is the software solution for analyzing steel nodes of any shape and under stress from any direction.
A powerful parametric 3D/BIM software enabling users to assemble steel connections without standardized type constraints, starting from the sections available in the comprehensive profile library to analyse their behaviour through a finite element analysis (FEM analysis).
Video steel nodes verification software | Steel connection design software list | NeXus | ACCA software
3D/BIM input and FEM solver for the design and analysis steel connections in real time of any node type | NeXus | ACCA software
3D/BIM input and FEM solver for the design and analysis of steel connections in real time of any node type
The input of NeXus is revolutionary!
Select node elements from a library of parametric objects, model the connection in 3D rotating it and modifying all components in real-time, resulting in an extraordinary design speed and control.
The input environment in NeXus is completely 3D. Design any type of connection in a much more streamlined and rapid method than other software with numerical input editors and three-dimensional views without any interaction.
Thanks to parametric three-dimensional modelling, you can easily achieve unions with a large number of rods and quickly indicate loads in multiple directions.
You have real-time stresses, deformations, strength reserves of the individual components and an immediate visualisation of the node behaviour with its safety margins.
With NeXus you can quickly tackle detailed design and connection analysis:
  • steel column beam node;
  • beam-to-beam connections;
  • steel beam-column union;
  • upwind ends;
  • complex multi-member connections;
  • steel-concrete*;
  • connections included in Eurocodes (EC) specifications.
Input, meshing and results are dynamic and give the designer an extraordinary awareness and ability to manage design and calculation.
* Feature not available at the moment
Ask for more info
Ask info for a steel connection software such as NeXus
Rigorous calculation methodologies steel connections and results always available for more conscious design, without material waste | NeXus | ACCA software
Rigorous calculation methodologies of steel connections and results always available for a more conscious design, without material waste and with lower costs
The software automatically creates meshes of plates, welds, bolts, anchors, ribs, stiffeners, flanges, joints, gussets, reinforcement plates, joint covers, base plates, etc.
From the 3D model of the union we quickly proceed to the finite element calculation, analysing the elastic-plastic behaviour of the elements by means of non-linear calculation*.
Automatic meshing and finite element calculation allow all stresses to be seen in real time on the 3D model and any changes to be made with new immediate and dynamic analyses.
NeXus analyses general steel connections, both by shape (i.e. for any type of rod to be connected) and by load direction.
You can say goodbye to calculation formulas from standards or technical literature that often involve a truly unacceptable degree of approximation.
The state of deformation and tension in the union are realistically determined using the finite element method, and simplifying assumptions (e.g. rigid plates) often used to know the stresses in the different components of the union are no longer necessary.
NeXus and its rigorous calculation engine allows you to optimise the size of union components, avoid unnecessary oversizing and material wastages and increase cost savings.
Ask for more info
Ask info for a steel connection design software for structures such as NeXus
Few steps to obtain consistent calculation and verification results of steel nodes with tension maps, printouts, reports and working drawings | NeXus | ACCA software
A few steps to obtain consistent calculation and verification results of steel nodes with tension maps, printouts, reports and working drawings
Thanks to the powerful graphics and calculation engine integrated in NeXus, modelling and calculation of any connection is very simple and fast, with automatic generation of the FEM model of the connection.
  • Various components are identified in the union: connected beams, plates, bolts, welds, etc;
  • All components of the union, within the framework of the FEM method, are appropriately schematised: connected beams and plates as shell elements, bolts discretized with finite elements and connected with links to the plates, welds modelled as a set of elements capable of transmitting and receiving parallel and orthogonal σ and τ;
  • The union analysis, employing either linear or non-linear calculations, yields the stress and deformation profiles of the various components;
  • Through the integrated FEM solver, various analyses are derived, including node stiffness analysis, fatigue analysis, and node capacity design specifically tailored for seismic zones*;
  • Buckling calculations promptly identify local buckling within the rods and determine critical load factors*;
  • Each component undergoes verification utilizing standard formulas (Eurocode, EC), with the FEM model's point response automatically interpreted to assess stresses directly comparable to material strengths;
  • Verifications encompass tensional and/or deformational assessments, incorporating diverse failure criteria when a normative verification is unfeasible.
From the analysis, we obtain clear information on the behaviour of the union/connection.
The results are tension maps that are able to represent all stress and test conditions at a glance.
Ask for more info
Discover how to manage the steel connection details with NeXus
Integration with any steel structure calculation software via IFC openBIM | NeXus | ACCA software
Integration with any steel structure calculation software via IFC openBIM®
NeXus is capable of obtaining geometry and union information from other modelling or calculation software (Revit®, ArchiCAD®, etc.) thanks to the IFC openBIM format.*
Simply export the entire structural model in the standard IFC format, identify the nodes and quickly retrieve all corresponding rods.
With NeXus, you can easily input detailed node detail information with intuitive graphical interface and get instant analysis and validation.
NeXus will also support the dynamic integration with between the EdiLus and Edificius solutions.*
Ask for more info
Ask info for a steel node verification software such as NeXus
FAQ Steel Connection Design software
For the verification of connections you can use Eurocode 3 (EN 1993-1-8) for steel connections
The traditional approach uses simplified formulas based on standardized failure mechanisms, with conservative assumptions (e.g., rigid plates, uniform stress distribution). The FEM method instead analyzes the actual behavior of the connection through finite elements, considering:
  • Complex geometries without simplifications
  • Actual distribution of stresses and strains
  • Non-linear material behavior
  • Interaction among all components of the connection
Advanced software like NeXus can verify any type of connection, including:
  • Beam-column connections (rigid, hinged, semi-rigid)
  • Bracing connections (diagonal and floor connections)
  • Continuity connections (beam-beam joints)
  • Complex three-dimensional connections (multi-directional intersections)
  • Atypical connections not covered by standard catalogs
Non-standard connections are joints that have geometries, loads, or configurations that do not fit the classic schemes found in technical literature. They include:
  • Connections with irregular or asymmetric geometries
  • Multi-directional connections with more than 4 elements
  • Connections with eccentric loads or complex load combinations
  • Localized reinforcements
With NeXus software, thanks to FEM modeling, you are free to model any geometric and load situation.
Bolt verifications include:
  • Shear strength of the shank and threaded sections
  • Combined bending and shear strength
  • Bearing resistance (plate crushing)
  • Punching shear resistance
Weld verification includes:
  • Shear check of fillet welds
  • Stress distribution in weld beads
Nonlinear FEM analysis considers:
  • Geometric nonlinearity: large displacements and deformations
  • Material nonlinearity: elasto-plastic behavior of steel, bolts, and welds
  • Contact nonlinearity: opening/closing of joints and interfaces
  • Instability phenomena: local and global buckling
  • Stress redistribution in the plastic range
Automatic meshing includes:
  • Automatic recognition of plates, bolts, welds
  • Generation of optimized meshes for each component
  • Local refinement in critical areas (holes, welds, edges)
  • Management of contacts between different components
Linear analysis: elastic materials, small displacements, superposition of effects.
Nonlinear analysis: real material behavior, large deformations, plastic stress redistribution, local instabilities.
Optimization requires:
  • Parametric analysis of different configurations
  • Balance between strength and material cost
  • Minimization of thicknesses while maintaining safety
  • Optimization of bolt layout
  • Elimination of unnecessary over-dimensioning
  • Consideration of ease of execution on site
Real-time visualization allows:
  • Immediate identification of critical zones
  • Instant modification of geometric parameters
  • Visual comparison of different solutions
  • Intuitive understanding of structural behavior
  • Reduced design times
  • Effective communication with clients and colleagues
To avoid oversizing:
  • Use rigorous calculations instead of conservative formulas
  • Exploit plastic stress redistribution
  • Optimize geometries for real loads
  • Eliminate redundant safety factors
  • Consider all available resisting mechanisms
BIM integration allows:
  • Automatic import of geometries and loads from the structural model via IFC model
  • Dynamic update in case of project changes
  • Information sharing among different disciplines
  • Automatic generation of construction drawings
  • Management of revisions and project history
  • Coordination with other software in the workflow
HELP
