Construction Scheduling Software
free construction scheduling | PriMus KRONO | ACCA software
The Construction scheduling software that helps you improve project efficiency and optimize work execution costs
Construction scheduling software free for one month | PriMus KRONO | ACCA software
One solution with all the tools for Project Time (Gantt), Economic and Financial planning.
Automatically produce Project Time Schedules directly from the project's cost estimate document prepared with PriMus, compare the estimate against works execution activities, monitor tasks, costs, timing and resources, get summary reports and diagrams and export them to Word® and Excel®.
Time-Schedule preparation | PriMus KRONO | ACCA software
PriMus KRONO is the software for creating a works time schedule including the analysis of timing, costs and resource requirements.
The software allows you to manage:
  • the design stage with GANTT charts, financial diagrams and resource reports;
  • the build stage with the execution GANTT chart, reports together with cost and timing variation diagrams.
A specific step by step procedure guides the user in defining the Time Schedule Plan, from creating the work item to defining quantities in the GANTT report.
Activities and Work Sections (Folders) allow the user to sub-divide time schedules into multiple levels and according to the most appropriate structure.
Activity data can be inserted either using analytic data entry dialogs or even graphically with features that allow the user to:
  • shift activities along the timeline;
  • define activity duration;
  • sub-divide them into multiple periods;
  • manage connections with critical paths.
Use it for free
Try the scheduling software for construction for one month
Produce Time Schedules from a .DCF file using Drag and Drop of activities to an easy to use timeline | PriMus KRONO | ACCA software
The Time Schedule can be generated by importing “.DCF” file produced with PriMus.
When importing a “.DCF” file (price list, BoQ or construction cost management documents) the generated time schedule document automatically acquires the necessary data, (general data, activities and unit rates, quantities and amounts and work sections).
You can import activities from other PriMus KRONO time schedules or from PriMus construction estimating with simple drag and drop actions.
Use it for free
Try the construction project scheduling software for free
Time schedule and financial plan management | PriMus KRONO | ACCA software
PriMus KRONO allows you to:
  • manage and customize climate conditions;
  • configure the calendar setting up work days and bank holidays;
  • choose the time scale;
  • define the schedule layout;
  • define a new commencement date for activities, periods or for the whole time schedule;
  • graphically represent work suspensions;
  • customize the graphical styles for each task bar.
By means of the financial definition of the project, PriMus KRONO allows the operator to control lead times, advances in work, guarantees, payments, etc.
With the economic and financial diagrams, daily productivity based data can be viewed filtered down to a given date, both during the planning and the works execution phases (work in progress).
Use it for free
Try the Construction Scheduling Software for free
Planned and Works Execution time-scheduling | PriMus KRONO | ACCA software
PriMus KRONO handles both the Planned and Works execution time-schedule in the same document: simply indicate the real works start date to get the works execution time schedule.
The execution time schedule is generated automatically from the project. It can be easily adjusted by shifting tasks or changing their duration. The works execution time-schedule indicates the amounts of work actually completed.
The completed work amounts can be displayed graphically or analytically by entering for each Activity or Period, the completed Quantities.
Use it for free
Use one of the best construction scheduling software for a month
Printing Time-schedules and Reports | PriMus KRONO | ACCA software
PriMus KRONO allows you to print the planned or works execution time schedule with the Table of Activities and Table of Dates and Amounts.
These documents can be printed or exported to Word, HTML or PDF file formats.
An internal word processor lets you create and manage your Time-schedule Report and the Works execution Report.
Reports can be printed on normal paper or exported in RTF format.
Use it for free
Rate Analysis work sections | PriMus KRONO | ACCA software
Rate Analysis of work sections
PriMus KRONO also integrates with the PriMus software taking full advantage of the Price List Management features: a list of time schedule activities can be opened as a normal PriMus Price List document and modified in its dedicated internal editor.
Any changes (for example rate percentage updates) are then re-aligned with the PriMus KRONO document.
The PriMus KRONO integration process with PriMus, makes it possible to edit work items and activity analysis (resources, quantities, costs…) or create new ones which will be automatically updated in the time-schedule.
Use it for free
Use one of the best free construction scheduling software for a month
Control of lead times and advances in work | PriMus KRONO | ACCA software
Use it for free
Use one of the best construction scheduling programs for a month
Printing Reports and management | PriMus KRONO | ACCA software
Printing Reports and their management
PriMus KRONO allows you to monitor the Project and Works Execution Time schedules at any moment, providing all the necessary data to assess effective resource availability to carry out the planned works on schedule.
In particular, specific Reports allow:
  • to view specific activity requirements even for user-defined intervals of time;
  • to evaluate material requirements deriving from work activity analysis (materials, labour, freight, etc.) and for certain date ranges;
  • to compare the Works execution time schedule with the Project time schedule to detect and underline changes (duration, Start and End dates);
  • to query Works Execution time schedule to highlight executed work amounts at a certain date, deviations from planned amounts specified on a given date or the programmed termination of the works date (i.e.: amounts still necessary for completion of works).
Use it for free
Try the scheduling integration software for construction
FAQ Construction Project Scheduling Software
The construction schedule is a fundamental document for planning and controlling the timing and costs of a building project. It allows you to visualize the chronological sequence of activities, the distribution of expenses over time, and the dates of work progress milestones.
It is used to plan and monitor the progress of the work, optimize resource use, meet contractual deadlines, and facilitate the economic management of the project.
Dedicated software like PriMus KRONO enables easy creation and updating of the schedule, graphical management of activities through Gantt charts, importing data from bill of quantities, monitoring resources, and generating detailed reports. It automates calculations and revisions, reducing errors and management time.
PriMus KRONO provides a guided procedure for creating the schedule, direct integration with PriMus bills of quantities, advanced management of activities and resources, graphical customization of the Gantt chart, automatic data updates, and detailed reporting for financial and operational project control.
You can directly import a “.DCF” file produced by PriMus. The software automatically generates the schedule with all activities, quantities, unit prices, and amounts already structured into the desired work categories.
Yes, PriMus KRONO allows you to graphically modify activities, shift them in time, split them into multiple periods, link them together, and thanks to integration with PriMus, update resources (materials, labor, equipment, etc.). Changes are automatically reflected in the document and reports.
PriMus KRONO lets you compare the project schedule with the execution schedule, view the quantities actually completed, analyze time deviations from forecasts, and query the financial plan to verify payments and work progress milestone dates.
The schedule and tables can be exported in Word, HTML, PDF, and some reports in Excel. It is also possible to generate technical reports in RTF format using the internal word processor.
Users have access to free online support, including online training, video tutorials, and forums, ensuring continuous learning and optimal software use.
PriMus offers you a free conversion service for price books and price lists.
If your database is in the Excel format, you can import it directly into PriMus. Alternatively, the conversion tool, PW-CONV, already provides you with various procedures for converting price list or price book databases (for which you must detain the license for use) into a format which is compatible with PriMus.
If the conversion procedure isn't available yet, you can always request a conversion using our dedicated service available in the program's Home section. Our team will then evaluate the feasibility of the conversion process.
The PriMus suite is composed of single stand-alone software solutions designed to meet every kind of specific need:
  • PriMus, for construction cost estimates, bills of quantities and works estimates;
  • PriMus KRONO, for construction project management, time scheduling and planning;
  • PriMus TAKEOFF, for preparing Cost Estimates and Bill of Quantities from CAD and PDF files;
  • PriMus IFC, for construction cost estimates from BIM Models.
The PriMus suite comparison chart:
  PriMus PriMus IFC PriMus PLUS PriMus FULL
COST ESTIMATE, BOQS AND QUOTES
BoQ and work estimate
Bids and proposals
Analysis of construction site needs
Accounting
Importing and exporting to standard formats (XLS, DOC, ...)
Import of databases, price lists and price books
QUANTITY TAKE OFFS FROM IFC FILES
Open IFC standard formats of BIM or 3D CAD models
View and navigate 3D BIM or CAD models directly in the integrated viewer
Assignment of Price List items to BIM or 3D CAD objects
Automatic measurements with artificial intelligence from 3D BIM or CAD model
Constantly updated cost estimate when editing the 3D BIM or CAD model
Data export in Word™, Excel™ formats
QUANTITY TAKE OFF FROM CAD DRAWINGS OR RASTER FILES
Opening of standard DXF/DWG CAD DRAWING FILES
Raster (PDF, BMP, JPG, etc.) management
Associate Price list items to graphical entities
Quantity Takeoff from CAD files
Quantity Takeoff from PDF files
Take off from image files
Dynamic BoQ updating when editing drawing models
Connection with your CAD or your CAD environment in PriMus TAKEOFF
CONSTRUCTION SCHEDULING
Integration with other Project time Schedules or construction cost estimates
Works financial plan analysis and control
Works resources analysis integrated with the construction cost estimate
Work resources analysis integrated within the BoQ document
Job resources requirements analysis
Activity scheduling, resources analysis between the design and construction phases
Data export in Excel and PDF
GANTT, charts and reports printout management
Yes, PriMus gives you free access to an International Database of online price books and price lists with numerous items, materials and prices for building and plant engineering works.
HELP
