Quick and easy access to maintenance information by means of Cloud-based services and QR-codes
To maintain a functional and efficient company over time it is necessary to pay attention to the maintenance of the systems.
Plant maintenance management is a complex task that can require a large investment of time.
usBIM.maint is a Computerized Maintenance Management System (CMMS) that allows you to define your plant's maintenance and strategic planning optimizing timing and intervention costs providing all relevant information in accurate data sheets stored securely and always available in the cloud.
Each object is managed through a special sheet that summarizes all the personal data and technical, maintenance and geographical information.
Even technicians in the field can take full advantage of the power of usBIM.maint thanks to the maintenance management app.
Through the Qr-code and/or Rfid labels applied on the components it is easier and faster to find the information related to the component directly in the field to efficiently manage ordinary and extraordinary maintenance.
Ask more info
Ask info for an easy plant maintenance software such as usBIM.maint
