Automatic construction drawings from the model
How often do you need to update the documentation after changes or corrections to your models?
With Edificius and the BIM modelling from 2D/3D architectural design, you can dynamically update your architectural drawings and all the project documentation (floor plans, cross-sections, elevation views, axonometries, isometric cut-away illustrations, perspectives, architectural reports, tables and schedules, land elevation profiles).
Drawings are dynamically connected with the BIM model; whenever the project changes, all relating documents and views will also be automatically updated.
Compose working drawings using simple drag & drop operations: just drag the drawings into paper space (including renders of your architectural project) and arrange them according to your creativity needs.
You can export all the graphics in DXF/DWG/DWF format and the reports in RTF format.
Furthermore, for the objects "Room", "Envelope", "Door" and "Window" Edificius groups in synthetic tables all the information related to assigned architectural zones, characteristics, materials and models, metric and geometric data, material layers, etc.
In addition to drawing models, with Edificius you get dynamic BoQ directly from the architectural model.
Find out more about the BoQ
