MEP software
Free MEP software | Edificius MEP | ACCA software
Do you think it is better to design your building’s installations systems in 3D but don't want to lose the freedom that your old CAD gives you?
Discover the BIM software for 3D modeling of installation systems, as simple as a CAD!
MEP BIM software | Edificius MEP | ACCA software
The new generation BIM MEP software for 3D modeling of mechanical, electrical and plumbing systems integrated with architectural design.
With Edificius you can continue to work with the same freedom as with a CAD, but with all the advantages of a BIM!
Video MEP software | Edificius MEP | ACCA software
Model in plan and section view and now also in 3D | Edificius MEP | ACCA software
Model in plan and section view and now also in 3D with the advantage of seeing and truly understanding how the entire system develops and affects the building.
3D, 4D and 5D dimensions dynamically integrated | Edificius MEP | ACCA software
You have the 3D, 4D and 5D dimensions dynamically integrated to avoid errors and wasting of time in drafting project documents, the cost estimate and the schedule of works.
Design your Installation systems in full integration with the architectural | Edificius MEP | ACCA software
Design your Installation systems in full integration with the architectural and structural layout while maintaining control of any interference and incompatibility aspects between the various design disciplines.
Real-Time rendering and Immersive Virtual Reality | Edificius MEP | ACCA software
Take a tour of the BIM model in an interactive immersive Virtual Reality experience to check every single detail and see your system as if it were already built.
Use it for free
Try the MEP design software for free,
together with free technical support, for a month.
You have an intuitive and adaptive "Smart MEP" modeler with intelligent component connections and automatic alignments
Edificius is feature-packed with unique design tools in the panorama of BIM modelling for MEP systems thanks to innovative 2D/3D modelling functions.
Forget working in 2D plan or section view to model your MEP systems - as you would with other "BIM Authoring" MEP modeling software - to model your systems: with Edificius you can finally deal with systems modelling in a simple and intuitive way also by working directly in 3D view with dedicated parametric objects.
The “Smart MEP” modeler makes the software behave adaptively showing exactly what the user expects automatically.
The individual elements (pipes, ducts, accessories, etc.) can be positioned using functions that simplify modelling operations with, intelligent connections alignment tools and automatic orientations.
Thanks to the intelligent connection ports, everytime a MEP object is added to the system, it is automatically adjusted and modified both from a geometric point of view (diameter, width, height, etc.) and in shape (inserting elbow joints, curves, fittings, etc...) for a correct and seamless connection with other components.
Find out more
Choose from installations modeling types | Edificius MEP | ACCA software
Choose from multiple installations modeling types
With Edificius you can model any type of network or system either inside or outside the building quickly and precisely with specific parametric objects.
Edificius allows you to choose between the following types of mechanical, electrical and plumbing systems:
  • electrical Watch the video
  • plumbing systems
  • fire extinguishing systems
  • Hydronic HVAC systems
  • direct expansion HVAC systems
  • Aeraulic HVAC systems
  • Drain, waste and vent systems
  • gas distribution systems
Use it for free
Try Edificius: BIM MEP software for a month
LODs design flows and manage | Edificius MEP | ACCA software
Follow design flows and manage LODs
With Edificius MEP you have the advantage of designing mechanical, electrical and plumbing systems while continuing to operate on the same model accessing an enormous amount of information.
The high level of detail that can be achieved with the simplicity and naturalness of Edificius allows you to concentrate on the best possible technical solutions and verify them immediately integrating architecture, structural, installation systems or other components of the building.
The natural and intuitive workflow of Edificius allows you to define the project LODs in a progressive way. Model the system using 3D parametric objects and when the appropriate degree of design detail is reached, it replaces the parametric objects with the corresponding manufacturer object..
This workflow does not force the designer to populate the project catalog in advance with hundreds of commercial objects during the modeling phase and contributes to making the whole MEP modelling process much easier and straight-forward to manage.
Create infinite BIM objects library with parametric MEP object configurator | Edificius MEP | ACCA software
Create an infinite BIM objects library with the parametric MEP object configurator
With Edificius you have free access to the rich BIM Objects Library containing the different types of pipes and ducting sections (mechanical, electrical and plumbing), fittings (curves, joints, transitions, plugs), special accessories, equipment and terminals (sanitary, heating systems , kitchen cabinets, etc.).
In addition, with the BIM MEP objects configurator, you create any specific component or installation system during the project design process.
After configuring the object, you can "match" it with the corresponding market product, upload it to the online catalogue and automatically utilize it in all new projects.
It is a unique and innovative method for finding an object, which starts from defining its functional characteristics in the project, offering maximum design freedom without binding component choices to those available in the catalog..
Find out more
Convert architectural objects into MEP objects | Edificius MEP | ACCA software
With Edificius you can transform 3D architectural objects into MEP objects and therefore design the MEP systems in consistency with other design choices, such as the furniture styles for instance.
All objects and 3D Models, useful for architectural representations (such as the sanitary appliances, kitchen furniture, heating systems, etc.) that are also part of the MEP system, can be converted into specific parametric MEP objects and customized with intelligent port connectors and other functional parameters for installations and systems modeling.
Use it for free
Try Edificius: MEP software download
MEP object from 3D model | Edificius MEP | ACCA software
Create new MEP objects from 3D models
With the same guided procedure proposed for converting architectural objects, Edificius-MEP allows you to create a new MEP object starting from a 3D model:
  • import the 3D file (.ifc, .skp, .obj, .dae, etc.)
  • select the category and type of an object similar to the one you want to create
  • enter the geometric properties corresponding to the 3D model
  • define the characteristic technical data and the object custom properties
  • insert the port connectors
Import and export models in the IFC format to interact with other BIM software | Edificius MEP | ACCA software
Import and export models in the IFC format to interact with any other BIM software
Edificius, fully compliant with the IFC Open-BIM philosophy, can import an IFC format file, even if produced with other architectural "BIM Authoring" software such as Autodesk Revit®, ArchiCAD®, etc. and can seamlessly export the MEP model according to the IFC CV2.0-MEP standard for further system design workflows.
Thanks to advanced automatic object recognition functions, with Edificius you can create a project starting from an IFC model created with other architectural, structural design software, etc.
LExport according to the IFC CV2.0-MEP standard applies to both the elementary objects and the "System": the grouping of objects that form the installations. The IFC model is then exported with the individual system objects categorized and ready for the subsequent design, verification and sizing phases by electrical and thermo-hydraulic designers.
The Edificius import and export features in IFC 2x3 format have the IFC Coordination View 2.0 certifications by buildingSMART International.
More information on the certification
Use it for free
Use one of the best MEP software
Print drawing models legends schedules and cost estimate data from the MEP model | Edificius MEP | ACCA software
Print drawing models, legends, schedules and cost estimate data, etc. directly from the MEP model
With Edificius automatically produce the following construction documents directly from the 3D model:
  • the system drawing plans
  • the project working drawings
  • a descriptive technical report of the project
  • a comprehensive components list
  • a detailed Bill of Quantities
Using different colours for the different installation systems, combined with different views of the building, offer multiple graphical and representation possibilities.
There are specific options - that allow you to view the upper or lower part of the system together with milder colour mapping - to obtain customizable and easier to read system drawings.
Use it for free
Try Edificius: BIM electrical software for a month
Simulate evolution of project over time | Edificius MEP | ACCA software
Simulate the evolution of the project over time
Edificius offers a "4D-GANTT" environment for an integrated time analysis management of the project. By building up a WBS (Work Breakdown Structure), you can break down the project into elementary parts (periods) and connect them to the model objects with simple drag and drop operations. By running the Gantt Timeline, you can see a visual simulation of how the different work phases progress in time.
Use it for free
Try Edificius: MEP Drawing software for a month
Share your projects on the usBIM collaborative platform | Edificius MEP | ACCA software
Edificius has advanced integration functions with the BIM collaborative platform usBIM.
usBIM is a data sharing environment designed specifically to start collaboration processes and simplify implementation of the BIM methodology even in small projects and small organizations.
The cloud platform of usBIM responds to the needs imposed by current regulations and technologies and allows the transition to BIM much easier and more accessible to everyone.
Find out more
View your building’s installation system and experience it with Real-Time rendering and Immersive Virtual Reality
Rendering with Artificial Intelligence (AI)
Edificius integrates the revolutionary AIrBIM technology that uses Artificial Intelligence to produce photo-realistic renderings in just a fraction of the time that traditional ray tracer engines do. Create professional renders without being an expert, without wasting time making adjustments and above all without doing any post-processing operations with other dedicated software.
Real-Time (RT) rendering
Edificius can also be integrated with RTBIM, a Real Time rendering technology that helps you to check your design choices in real time. In Real-Time rendering view, you can move around the BIM model exploring different details and scenarios. At a simple click of a button, you can produce a High-Definition rendered image instantaneously. Everything is perfectly and dynamically integrated respecting the true BIM philosophy.
Further integration allows you to add VRiBIM technology to Edificius to explore and navigate throughout your MEP designs in a 1:1 true life-like scale. Each BIM model becomes an interactive environment that responds to user inputs supporting immediate ideas for improving the project. Thanks to VRiBIM, it’s much easier to try different design solutions and evaluate their feasibility in real time.
Use it for free
MEP software free download for a month
FAQ MEP software
The acronym MEP (Mechanical, Electrical, Plumbing) refers to the BIM design of mechanical, electrical and plumbing systems. MEP systems are important part of the building services that allow you to obtain an overall model of the architectural, structural and plant design, so as to avoid errors and inconsistencies between models.
With Edificius you can model directly in 3D mechanical, electrical and plumbing systems that are integrated in the architectural model, so to always have control over possible interferences and incompatibilities between the various installation systems and without having to switch from different views.
Edificius allows you to maintain control of the 3D model, with the possibility of modeling without limits and without obstacles. One of the great advatages of using Edificius is being able to view how each single system component is articulated in space and how it interacts with the whole installation system already during design stage, by reducing the possibility of design errors. In addition, you can hide some parts of the model to have an overview of the systems and find the best solution to integrate them with the structure and other components of the building.
Smart MEP is an innovative modeler that allows you to obtain connections between various elements of the same type (e.g. between two ducts), automatically generating all the fittings. In short, Smart MEP modeler makes the software behave adaptively, showing exactly what the users expects automatially.
Smart MEP dynamically modifies objects shape and geometry by:
  • automatically inserting curves and other fittings;
  • changing the geometry dimensions;
  • automatically connecting objects thanks to intelligent port connections.
Furthermore, you can create an infinite BIM objects library with the perametric MEP object configurator.
Working with Edificius is very easy. From the Drawingmenu, select the section dedicated to electrical systems which are grouped into:
  • pipes and corrugated;
  • ducts and trays;
  • accessories and general switchboards;
  • equipment and devices.
You have access to a wide collection of MEP objects to insert in your architectural model and create a complete electrical system.
MEP systems modeling | MEP elements menu | Edificius MEP | ACCA software
With the BIM MEP objects configurator in Edificius, you can create any specific component or installation system during the project design process in three different ways:
  • Create a new MEP object by using the parametric configurator – when the window pops up, you can select the category and type of object and, subsequently, insert object characteristic data;
  • Create a new MEP object by importing the 3D model from a file – select the 3D object from the specific folder, then associate it to a category, insert and/or modify the object data and finally insert and/or modify the connectors;
  • Create a new MEP object by converting an architectural 3D block – select the 3D object and, with the use of the magic wand, associate it to a category, then insert and/or modify the object data and finally insert and/or modify the connectors.
In Edificius you can quickly produce all the project drawings such as area views, floor plans, elevation views, cross-sections and 3D views of the installation system. You can add legends to the documents with the MEP object legend command by selecting the elements of your interest.You can also label all the objects on the 2D work space in a quick way. In fact, the software recognizes the element and automatically shows all the object data in the labels.All project drawings are dynamically connecred to the drawing environment, therefore when modifying the project you will have all the project drawings always updated.
You can print the project drawings individually or arrange them in a single working drawing.Choose the format and title block and drag & drop the generated graphic tables complete with legends and symbols. You can also enrich it with photos and realistic views of the systems, obtaining a very professional result. The above can also be applied to tables and schedules.They can be printed on paper, exported in different formats or even dragged directly onto the working drawing in order to have all the technical details of the objects shown on the project drawing.
Project drawings in a single working drawing | Edificius MEP | ACCA software
With Edificius you can both import and export your installation systems project in IFC format. The IFC is an open and non-proprietary data format that facilitates the interoperability and exchange of information relating to the BIM model between the various figures involved in the same project.
You can browse the 3D model of the systems in different ways by taking advantage of the Real Time Rendering module that allows you to experience the model from your computer or by using the Immersive Virtual Reality. Using a VR headset you can walk within the model and explore or change the objects:
  • explore the whole project, look in all its details, as if it were already built, obtaining a realistic perception of spaces, environments, materials and the interference between the different systems modeled;
  • the use of controllers allows you to cross the various environments and query any attachments and documents associated with the objects;
  • by applying the transparency function, you can observe the layouts and all the system components while browsing the virtual environment, obtaining immediate feedback on the most appropriate design choices;
  • the project presentation becomes a dynamic and interactive experience with the advantage of testing, in real time, all the changes requested by the client.
