HBIM (Historic Buildings)
HBIM - Historic buildings | Edificius | ACCA software
Looking for professional and powerful tools for creating a survey of an existing building, representing typical heritage degradation zones, modelling heritage preservation works?
Discover Edificius, the most advanced 3D modelling software technology applied to the conservation, protection and recovery of existing buildings and historic and monumental buildings.
BIM for heritage buildings | Edificius | ACCA software
Edificius revolutionizes the digitization of existing and historical building heritage (HBIM)!
Video Historical BIM | Edificius | ACCA software
A dedicated environment
for HBIM modelling
Building's digital model | Edificius | ACCA software
Create the building's digital model from a point cloud survey or DXF/DWG/IFC files
HBIM modelling | Edificius | ACCA software
Model in 2D and 3D with specific HBIM objects for the recovery of existing and historic buildings (vaults and domes, ribs, wooden floors, niches)
Import architectural and decorative elements | Edificius | ACCA software
Import architectural and decorative elements from SketchUp®, Revit®, Blender® or Rhino-Grasshopper®
Orthophotos | Edificius | ACCA software
Position orthophotos with building elements to obtain two-dimensional architectural element elevations and façade mappings
Crack pattern of the existing building | Edificius | ACCA software
Obtain a realistic representation of the actual state and the crack pattern of the existing building, identifying and recreating injuries and degradation areas
Try the HBIM software for free together with free technical support, for a month.
What is HBIM (Heritage BIM) and what are its advantages when applied in restoration and redevelopment projects
The acronym HBIM (Heritage Building Information Modelling) specifies the application of the BIM methodology to:
  • modelling of historic buildings;
  • damage and decay area surveys management;
  • assisted planning tools for restoration, recovery, protection, conservation and maintenance of existing heritage assets.
Modelling a historic building means taking into account the presence of non-standard elements characterized by deformations and irregularities, survey uncertainties regarding construction techniques, the presence of degradation phenomena, etc.
BIM processes, together with the most recent surveying techniques (laser scanners, drones or cameras for terrestrial photogrammetry) can now fulfil the promise to overcome the traditional obstacles of designing recovery and redevelopment interventions offering extraordinary advantages in terms of precision, high speed 3D models processing, data availability and sharing, maintenance interventions scheduling, promotion and use of the asset with advanced technologies (such as virtual or augmented reality).
What is HBIM and what are its advantages | Edificius | ACCA software
3D digital model building starting from survey with point clouds | Edificius | ACCA software
Create a 3D digital model of the building starting from the survey with point clouds or from DXF/DWG/IFC drawings and models
With Edificius you can:
  • import point clouds (using the survey data acquired from laser scanners or cameras for terrestrial photogrammetry)
  • import drawings in the DXF/DWG file format
  • import the BIM model IFC file to automatically recognize objects
  • build the model by manually inserting objects (walls, floors, windows, etc.) together with measurements acquired from the site survey
You can also import land survey data into Edificius (with Google Maps or with other land survey files in DXF/DWG CAD formats) defining contour lines, plans and altimetric points.
Use it for free
Use for free the environment BIM for Heritage buildings
Design vaults and dome types choosing from variety of objects | Edificius | ACCA software
Design a multitude of different vaults and dome types choosing from a variety of objects
Ever experienced the difficulty of modelling vaults after an existing heritage building survey?
With Edificius you can easily and rapidly model different types of vaults using new specific objects: barrel, rampant half-barrel, pavilion, polygonal base pavilion, cross-ribbed, domes, lunettes/hole, horizontal and vertical plane).
Without the need of any external modellers! Edificius guides you in defining the overall vault surface, the lower reference level and "delta".
Quickly customize the vault detailing elements such as the pier, infills, lunettes, arch positioning.
See a model preview from directly within the editor and observe the final result either in 3D view or in the Real-Time Rendering environment.
Use it for free
Heritage building design software free for one month
Insert ribs on the vault | Edificius | ACCA software
Insert ribs with a simple click on the vault
With Edificius you can automatically insert ribs on any edge both at intrados and extrados of the vault.
Thanks to the use of the magic wand tool, simply position the ribs on a solid extrusion, on a magnetic grid or on the curvatures of a previously modelled vault.
Use it for free
HBIM software free for one month
Model the wooden floors | Edificius | ACCA software
Model the wooden floors down to the smallest detail
With Edificius you can create and customize your HBIM model wooden floor decks in plan or 3D view by quickly defining:
  • the affected surface;
  • the spanning direction;
  • material layers (thickness, materials, etc.);
  • the section, the center distance (fixed pitch, by number, etc.) and the joist rotation angles.
Use it for free
Historic house software free for one month
Reproduce niches | Edificius | ACCA software
Reproduce niches with their elements characterizations
Insert the "niche" object into the HBIM model, even starting from an orthophoto.
Define the niche faithfully following the photographic survey while reproducing its geometric properties.
Define the thickness, depth and wall material layers with the aid of an extensive object library provided for free with the software.
Align the niche in relation to the wall, insert and define reveals, define the threshold (single or double-sided) and apply windows or doors.
Use it for free
BIM heritage software free for one month
Draw architectural elements by importing 3D objects | Edificius | ACCA software
Draw architectural and decorative elements of any kind by importing 3D objects from SketchUp®, Revit®, Blender®, Rhino/Grasshopper®...
In addition to specific objects for HBIM modelling, with Edificius you have all the tools to insert particularly complex architectural and decorative elements such as capitals, pilasters, frames, etc. into the project. while taking advantage of the integration with other solid modellers such as SketchUp®, Revit®, Blender®, Rhino/Grasshopper® and download 3D model objects from the web in these formats: .3DS, .SKP, .OBJ, etc.
Use it for free
Associate orthophotos to the building elements
Edificius allows you to associate an orthophoto with a part of the historic or existing building to:
  • represent two-dimensional elevations of architectural elements
  • define façade mappings (with the qualitative/quantitative identification of materials that form the surface and alteration and degradation phenomena)
Associate orthophotos to the building elements | Edificius | ACCA software
Recreate damage and decay areas | Edificius | ACCA software
Identify and recreate damage and decay areas
The 3D model can be used as a basis for analysing the surveyed stage and for defining interventions at the design stage. With just a few simple steps, you get:
  • a realistic representation of the surveyed stage together with a detailed overview of the building’s crack patterns with orthophoto overlays
  • representations of degraded areas with their relating fills and legends
  • a BIM model that can be consulted, implemented and updated over time
  • detailed drawings with photorealistic elevations
  • photorealistic renderings of the model to be used for project presentations.
Damaged zones and degradation areas aren’t just simple graphical representations but BIM objects capable of providing all the necessary crack pattern data and information.
Simply trace the building’s damage zones using the "brush" tool, assign its characteristics (type, severity, causes), define and assign its "Symbology" and automatically obtain legends to be included in the final working drawings or construction documentation.
Also identify entire areas of decay with the same methodology. For each degradation phenomenon define depth, classification and thickness.
The decay tables and legends are automatically generated according to the NorMaL classification (unified method for studying the alterations of stone materials and for checking the effectiveness of conservation treatments of artefacts of historical and artistic interest) and are automatically updated at each change to the model.
Use it for free
Produce technical documentation and photorealistic renderings model | Edificius | ACCA software
Produce technical documentation and photorealistic renderings of the model
HBIM model completed:
  • automatically generate the project documentation (plans, sections, elevations, etc.)
  • isometric views
  • working drawings
  • dynamic cost estimates
Even navigate within the spaces in first person using Real-Time Rendering or Virtual Reality technology.
Use it for free
Manage and share HBIM model in the Cloud | Edificius | ACCA software
Manage and share the HBIM model in the Cloud
Thanks to the integration with usBIM, you can manage and share the HBIM model online and take advantage of all the benefits of the cloud:
  • geolocate the digitized historic building with thematic GIS maps
  • access all data, documents and models from anywhere using any device
  • browse and federate 3D models from a simple web browser
  • collaborate with other designers in real time with online instant messaging, video meetings, etc.
  • store, connect and collaborate all survey files in a single sharing environment together with graphical and descriptive drawings, technical datasheets with degradation analysis, crack patterns, restoration interventions, project drawings relating to surfaces conservation, etc.
Use it for free
