Landscape Design Software
Free Landscape Design Software | Edificius LAND | ACCA software
Looking for a garden design and exterior rendering software?
Learn more about how to develop gardens and public spaces with a professional landscape design software
Use it for free Book a free live demo
Garden design software free to use for a month | Edificius LAND | ACCA software
Design gardens, public spaces, terraces, patios, courtyards, swimming pools in 2D and 3D, with the most powerful, easy to use modelling tools
Get detailed area plans automatically. Amaze and convince your customers with superb eye-catching renderings combined with engaging immersive experiences
Video Professional Landscape Design software | Edificius LAND | ACCA software
Model terrain | Edificius LAND | ACCA software
Modeling of land profile from topographic surveys or Google Maps™
Model your land profile by defining contour lines and contour plans starting from topographic land surveys in DXF/DWG formats or directly from Google Maps™
Design 2D/3D | Edificius LAND | ACCA software
Design with dedicated BIM objects
Design in 2D and 3D with an extensive library of dedicated BIM objects and 3D models imported from Revit®, SketchUp®, Blender®, Rhino-Grasshopper®, Collada ™, 3dsMax®, etc.
Get detailed project drawings by drag and drop | Edificius LAND | ACCA software
Automatic project drawings
Automatically produce and update all project drawings (area plans, sections, axonometries, legends) and export them to DXF and DWG
Dynamic construction cost estimates | Edificius LAND | ACCA software
Dynamic summary of cut & fill volumes
Get a complete and detailed summary of cut & fill volumes dynamically updated with each change
Produce high quality render | Edificius LAND | ACCA software
Photorealistic renderings
Create photorealistic renderings, photomontages, use Real-Time Rendering as a modelling and design validation tool, create videos for visually appealing ArchViz presentations
Project Immersive Virtual Reality | Edificius LAND | ACCA software
Virtual tour
Take a virtual tour of your project in virtual reality with the possibility to interact and edit objects and design assets in real-time while creating extraordinary presentations
Use it for free
Try Edificius the Landscape Design Software for Professionals together with free technical support
for a month, then choose the subscription plan that suits you best.
2D-3D Modeling | Edificius LAND | ACCA software
idea spectrum | Edificius LAND | ACCA software
Render Garden | Edificius LAND | ACCA software
Modeling Garden | Edificius LAND | ACCA software
Realtime landscaping | Edificius LAND | ACCA software
Render Terrain modelling | Edificius LAND | ACCA software
Architectural projects rendered with Edificius, the landscape design program
3D landscape design software to deal garden design and digital terrain modelling | Edificius LAND | ACCA software
Edificius includes a 3D landscape design software to deal with both your garden design and digital terrain modelling needs
With Edificius you have a complete set of advanced functions for digital terrain modelling in addition to gardens and outdoor spaces design:
  • use the specific objects for terrain elevation modelling based on contour lines or triangles;
  • work seamlessly in 2D or 3D views;
  • use DXF or DWG CAD files, raster images or satellite photos from Google Maps™;
  • simulate earthworks (cuts and fills) and obtain automatic and accurate calculations;
  • design gardens and landscapes in 2D or 3D;
  • integrate architectural projects created with any other BIM authoring;
  • import any type of 3D building or structure produced with other 3D/BIM design software (Autodesk® AutoCAD®, Autodesk® Revit®, NemetscheK® Allplan®, Graphisoft® ArchiCAD®, Trimble® SketchUp® etc.) directly from the standard IFC BIM format.
Find out more
Use it for free
Land design software free download
Customize exterior project with BIM objects from online Library | Edificius LAND | ACCA software
Customize your exterior project with BIM objects available from the online Library or by importing your models from Revit®, SketchUp®, Blender®, Rhino-Grasshopper®
Design terraces, winter gardens, swimming pools, patios, green roofs and outdoor furniture with dedicated high quality objects, with special attention to finishes, furnishings, curtains and materials.
Design your garden directly in 3D thanks to an extensive online library of BIM objects already optimized for your softscape and hardscape design needs. Insert or import vegetation objects, including trees, shrubs, bushes, plants and detailed garden furniture even if produced with other third-party 3D modeling software.
The powerful “Vegetation” object makes things even quicker, allowing you to cover huge areas or insert trees, bushes and different kinds of plants along a predetermined path. Vegetation will be automatically distributed on your landscape plan randomly for a harmonic and realistic result.
Use it for free
Landscape architecture design software free to use for a month
Design quality for irrigation systems | Edificius LAND | ACCA software
Better decision making, improved design quality for your lighting and irrigation systems thanks to specific functions fully integrated into the 3D landscape design software
Edificius supports you during all phases of the design process allowing you to model any type of irrigation or technical system exterior to the building in a quick and precise manner both in 2D and in 3D.
Design garden irrigation systems (submersed irrigation, lateral infiltration irrigation, sprinkler irrigation, shower irrigation).
Complete your external architecture designs with a precise lighting layout:
  • choose between overhead or underground lighting systems;
  • define your light source positions and types in relation to the installation area;
  • select your lighting systems (recessed spotlights, floodlights for plants and vegetation, street lights, lamp posts or decoration lights, etc.) in complete freedom according to your preferred design solutions.
Thanks to the rich Library of BIM Objects, choose between different types of pipes and ducting systems (electrical and hydraulic), fittings (curves, joints, transitions, plugs), special connection parts, equipment and terminals.
Even create your own custom components for specific use within your project and without having to rely only on the objects available in the library.
Find out more
Use it for free
Use one of the best 3D garden design software
Design outdoor spaces | Edificius LAND | ACCA software
Design outdoor spaces: generate your construction drawings automatically together with detailed and dynamically updated project cost estimates
With the Edificius exterior spaces design software, get all project drawings automatically from the 3D/BIM model: area plans, sections, axonometric views, legends, etc.
All drawings can also be exported in DXF and DWG CAD file formats while technical reports can be saved in the RTF format.
The project cost estimate is produced automatically and dynamically: each variation of the project corresponds to a variation of the estimate data and therefore the total cost of the project.
The software's cost estimate section, calculates earthwork volumes based on the modelled cut & fill operations together with all the softscape and hardscape design elements present in the project (roads, squares, ramps, canopies, trees, furnishings, etc.).
Use it for free
Free landscape design software for a month
Photorealistic renderings, visually presentations and immersive experiences of your outdoor spaces designs | Edificius LAND | ACCA software
Create highly photorealistic renderings, visually appealing presentations and immersive experiences of your outdoor spaces designs
With the Edificius landscaping software you have a complete set of professional tools to amaze your client and convince more:
  • Photorealistic renderings
    External renders with transparent backgrounds, magic render, clay render, etc.
  • Easy to use photo editing
    and photomontage tools
  • Real-Time Rendering
    Produce superb real time rendering content while continuing the BIM design process with the RTBIM add-on module. Present the project to your customer, change materials, furnishings and shapes according to specific requirements or indications given by the customer. Validate changes in real time.
  • Video Editing
    tools allow you to produce multimedia presentations with the BIM Video Studio time-line editing tools. Create and share responsive 360° panorama images to social media directly from the Real-Time rendering environment.
  • usBIM
    With Edificius you can publish your 3D models online and share them with everyone. The software saves the BIM file to the cloud and creates a link to share access to the 3D BIM model.
Use it for free
The BIM Software Landscape Design for a month
Virtual tour of your landscaping design in immersive virtual reality | Edificius LAND | ACCA software
Take a virtual tour of your landscaping design in immersive virtual reality
With the VRiBIM technology - that you can integrate in Edificius - take a tour of your 3D BIM model in Immersive Virtual Reality.
take advantage of the dynamic integration between the BIM model and Virtual Reality to create immersive experiences for your customer, but also to modify the model from the "virtual garden", try different solutions, test design variations together with the client.
Find out more
Use it for free
The free landscaping design software for a month
Examples of landscape and garden designs created with the Edificius garden and landscaping design software
Public spaces design | Edificius LAND | ACCA software
Download the sample project
These projects are in .EDF format.
Open and edit them with Edificius
Use it for free
3D landscape design software free for one month
FAQ 3D landscape design software
Garden and outdoor space design is the process of organizing an outdoor area from a functional, aesthetic and technical perspective. It includes the definition of pathways, green areas, materials, furnishings, lighting, irrigation and terrain modelling, with the aim of creating spaces that are attractive, easy to use and consistent with their surroundings.
Before starting, it is useful to assess the size of the area, sun exposure, climate, slopes, soil type, access points, any constraints and the functions required of the outdoor space. This preliminary analysis helps you choose the most suitable plants, materials, pathways and systems.
The main stages are: surveying the existing conditions, developing the layout concept, selecting plants and materials, defining pathways and furnishings, designing lighting and irrigation systems, 3D modelling and producing the final technical drawings.
3D software helps you visualize the project realistically, check proportions, elevations and integration into the landscape, compare alternative solutions and present the work more effectively to the client using renderings, immersive views and technical drawings.
Yes, garden and outdoor space design software is useful for both large areas and smaller spaces such as terraces, patios and courtyards. In compact spaces, it allows you to optimize dimensions, pathways, furnishings, greenery and lighting with greater precision.
A garden design can include plants, trees, hedges, flower beds, pathways, paving, pergolas, gazebos, swimming pools, furnishings, fences, lighting fixtures and technical systems, arranging them consistently with the style and intended use of the space.
To present a garden design effectively, it is useful to combine plans, 3D views, photorealistic renderings, technical drawings and, where possible, immersive experiences. This allows the client to immediately understand the layout, materials, atmosphere and functionality of the outdoor space.
Having a single working environment makes it possible to develop the building and outdoor spaces seamlessly, improving coordination between elevations, materials, systems, views and documentation. This is particularly useful in projects where the landscape needs to interact harmoniously with the architecture.
YES. With Edificius you no longer need multiple software solutions for your architectural design. With a single software you can now deal with architecture, outdoor spaces and gardens, interior design, mechanical, electrical and plumbing systems.
Terrain and land modeling, together with outdoor spaces and gardens design aspects, are specific Edificius functions available in a dedicated environment integrated in the software.
The modeling of MEP systems (mechanical, electrical and plumbing) are specific Edificius functions available in a dedicated environment integrated in the software.
You can integrate Edificius with a wide range of ACCA software solutions.
You have dynamic integration features with Sketchup®, Grasshopper®, Revit® and Blender® for modeling free-form solids.
Also use the full power of a native 2D and 3D DWG CAD software, Edificius CAD, included for free in Edificius.
Import and export the architectural BIM model in the IFC format. Get topographic and land survey data directly from Google Maps™ satellite imagery.
Yes, AIrBIMpro2 rendering technology with Artificial Intelligence (AI) is already integrated in Edificius.
Yes, the RTBIM Real-Time Rendering (RTR) technology is provided in both Edificius with the optional RTBIM module.
Yes, the VRiBIM immersive Virtual Reality (VR) technology can be integrated in Edificius with the optional VRiBIM module.
YES. With Edificius you can collaborate in the BIM process in complete safety because it has obtained certification by buildingSMART.
BIM (Building Information Modeling) is increasingly a reality that involves collaboration, interoperability and coordination between the various stakeholders of the construction industry. With Edificius you can collaborate securely with all the best Authoring and BIM Tools certified by Building Smart International.
More information about the certification
3D building design makes it possible to identify and resolve clashes between structures, systems, and architecture before construction begins. The BIM model can be exported in IFC format and imported into usBIM.clash, the BIM Clash Detection software used to verify interferences and manage conflicts between different openBIM IFC models.
Thanks to clash detection (automatic detection of collisions within the BIM model), costly changes during construction are avoided. According to industry studies, BIM projects achieve an average reduction in construction costs between 10% and 20% compared to traditional 2D methods, precisely because every error is corrected virtually rather than physically on-site.
Traditional 3D modeling produces three-dimensional representations of the building that are visually complete but "empty" of information: they are essentially geometric solids without technical data. BIM (Building Information Modeling) adds a structured set of information to each 3D element: materials, performance, costs, manufacturers, energy classes, and installation specifications. This difference transforms the model from a simple three-dimensional drawing into a digital twin of the real building, usable throughout the entire lifecycle of the project: from design to construction, all the way to the building’s management and maintenance.
