BIM Objects Library
BIM Objects Library | Edificius | ACCA software
Looking for high quality design resources for your projects and renders including CAD blocks, 3D models, BIM objects, materials and textures?
With Edificius you can access an extensive library with thousands of free and constantly updated resources. Everything you need to bring extra realism to your renderings and more value to your architectural and interior design projects.
3D BIM object | Edificius | ACCA software
Access thousands of free resources | Edificius | ACCA software
Access thousands of free resources available in a constantly updated online library
Library of architecture design assets including 2D CAD blocks | Edificius | ACCA software
Full freedom to access an extensive library of architecture design assets including 2D CAD blocks, optimised 3D Models, textures, material layers, profile sections, etc.
Publish your models created with Edificius in online library | Edificius | ACCA software
Publish and share your models created with Edificius in the online library
Import files and models into the library | Edificius | ACCA software
Import files and models into the library from Revit ®, Sketchup ®, Blender ®, Rhino-Grasshopper ®
Choose BIM objects from the General Library, create Project libraries and collect your customized models in the User Library | Edificius | ACCA Software
Edificius has 3 different types of BIM libraries:
  • usBIM.library, the software-integrated online BIM object library with 2D  blocks, 3D models, materials and colors, material layers, doors, windows, profiles, railings, panels, trees, etc. that you can freely use in your projects as models for objects
  •  project libraries: collect the entities used or created by the user for a given project.BIM objects entered in the "Project Library" can be freely modified and customized
  • user libraries: you can create your "custom" libraries on usBIM.library with custom BIM objects to share or publish.
The BIM object libraries are easy to consult, use and customize. Direct access to all libraries with an in-built editor to modify elements or materials with a simple click.
Easily transfer libraries (or single objects or groups of objects) from one workstation to another by exporting (and importing) with the .BOL format.
Use it for free
Download any 3D BIM objects for free for a month
Enrich your projects with BIM objects, 3D models and textures from the comprehensive usBIM.library service | Edificius | ACCA Software
With Edificius you can easily create new types of objects and specific object libraries in the .BOL, .IFC and Revit formats or simply import external BIM objects by downloading them from other external online libraries or from usBIM.library, the vast online library of textures, CAD blocks, 3D models and BIM objects.
From the online library you can download objects for free, choose from thousands of generic furnishing, architectural or plant solutions or created by the most well-known brands and leading worldwide manufacturers for architects, engineers, builders and designers (Natuzzi, Smeg, Artzzi, Whirlpool, Caleffi, Catalano and many others).
All online library resources are parametric and fully customizable.
Forget about having to draw all the project details with lines, polylines and geometric shapes by yourself.
Insert objects with specific properties directly in 3D, adapt them to the project and visually verify the final result of your choices in Real-Time rendering.
Each element of the library is grouped in specific categories and subcategories making it much easier for the user to search for particular objects. Here's an example (only referring to the main categories present):
Explore the online library now
Brands and manufacturers available in the online BIM objects library usBIM.library
Artzzi
Artzzi
Bertazzoni
Bertazzoni
Bla station
Bla station
Cgaxis
Cgaxis
CGM
CGM
Cosmic
Cosmic
Deca
Deca
Dekker
Dekker
Extremis
Extremis
Fiora
Fiora
GameTextures
Game-Textures
Geniale
Geniale
Gervasoni
Gervasoni
Globo
Globo
Green Furniture Concept
Herman Miller
Herman Miller
Hewi
Hewi
Hitchmylius
Hitchmylius
HORM
HORM
Idealstandard
Idealstandard
Intra
Intra
Kare
Kare
Keystone Ridge Designs
iGuzzini
iGuzzini
KitchenAid
KitchenAid
Laura Meroni
Laura Meroni
Lekolar
Lekolar
Liebherr
Liebherr
Lofra
Lofra
Luazzu
Luazzu
Lumec
Lumec
Lumina
Lumina
Marelli
Marelli
Marshalls
Marshalls
Martinelli luce
Martinelli luce
Merillat
Merillat
Mora
Mora
Natuzzi
Natuzzi
Nola
Nola
NORR11
NORR11
Paini France
Paini France
Panda Kitchen
Panda Kitchen
Panzeri
Panzeri
Roca
Roca
Sala Bella
Sala Bella
Schuster
Schuster
Senia
Senia
Sierra
Sierra
Smeg
Smeg
Solzaima
Solzaima
Stolab
Stolab
Svedbergs
Svedbergs
Thosmoser
Thosmoser
Vitra
Vitra
Whirlpool
Whirlpool
A wide selection of Edificius BIM objects are also available in these formats .BOL (BIM Object Library) on the www.bimobject.com portal, the marketplace for the construction sector with over 2,000 brands of specialistic products.
Publish and share the BIM objects and 3D models you have created in the online library | Edificius | ACCA software
Use the online library to publish your own Edificius 3D models and BIM objects and share them with collaborators and the rest of the user community.
Publishing and sharing your creations is super easy:
  • select the object you want to publish in usBIM.library;
  • click on the "Publish" icon;
  • each object can be organised within the library with a category type, a title, description, additional keywords for improved object searching;
  • publish and share objects in the online BIM Object Library.
Use it for free
Use the BIM library for free for a month
Import and customize models from many other formats
Import and customize models from Sketchup®, Blender®, Rhino-Grasshopper® and many other formats...
All you need is in the library, but you can import new objects and customize the library contents according to specific needs:
  • create 3D solid models of any type and shape with Sketchup®, Blender®, Rhino-Grasshopper® and seamlessly import them into Edificius;
  • with the "3D Model" object, easily insert external objects available in many other well-know formats (such as: OBJ, 3DS, DAE, DWG, etc.) and created with other 3D solid modelers or provided in other online object portals such as BIM Object, SketchUp Warehouse 3D, Trimble, etc.
Use it for free
Convert RVT/RFA files into library using usBIM integration | Edificius | ACCA Software
Convert and import Revit files (RVT/RFA) into the library using the usBIM integration features
With Edificius, easily import 3D models created and exported with Revit (RFA/RVT) ready to use and integrate them into your projects.
Thanks to the integration with usBIM:
  • upload models to your usBIM cloud space;
  • view the model and select the elements you need (avoid importing unnecessary elements)
  • convert and import the model directly into the Edificius library.
Once the model has been imported, you can acquire and modify it with Edificius just as you would do with any 3D model: assign materials, customize it, integrate it in the project and view the final result in Real-time rendering...
Use it for free
FAQ
YES. With Edificius you no longer need multiple software solutions for your architectural design. With a single software you can now deal with architecture, outdoor spaces and gardens, interior design, mechanical, electrical and plumbing systems.
Terrain and land modeling, together with outdoor spaces and gardens design aspects, are specific Edificius functions available in a dedicated environment integrated in the software.
The modeling of MEP systems (mechanical, electrical and plumbing) are specific Edificius functions available in a dedicated environment integrated in the software.
You can integrate Edificius with a wide range of ACCA software solutions.
You have dynamic integration features with Sketchup®, Grasshopper®, Revit® and Blender® for modeling free-form solids.
Also use the full power of a native 2D and 3D DWG CAD software, Edificius CAD, included for free in Edificius.
Import and export the architectural BIM model in the IFC format. Get topographic and land survey data directly from Google Maps™ satellite imagery.
Yes, AIrBIMpro2 rendering technology with Artificial Intelligence (AI) is already integrated in Edificius.
Yes, the RTBIM Real-Time Rendering (RTR) technology is provided in both Edificius with the optional RTBIM module.
Yes, the VRiBIM immersive Virtual Reality (VR) technology can be integrated in Edificius with the optional VRiBIM module.
YES. With Edificius you can collaborate in the BIM process in complete safety because it has obtained certification by buildingSMART.
BIM (Building Information Modeling) is increasingly a reality that involves collaboration, interoperability and coordination between the various stakeholders of the construction industry. With Edificius you can collaborate securely with all the best Authoring and BIM Tools certified by Building Smart International.
More information about the certification
