BIM Clash Detection Software
BIM Clash Detection Software | usBIM.clash | ACCA software
How do you deal with BIM models clash detection?
Discover the BIM clash detection software to use as a desktop solution or directly online
Use the PC version for free  Use it for free online
usBIM.clash is available as a desktop version and application integrated in usBIM. Try it for free for a month; then choose the subscription plan that suits you best.
Clash detection system | usBIM.clash | ACCA software
The BIM Clash Detection software for checking interferences and collisions while managing conflicts between different IFC openBIM models
Video Checking BIM element interferences and conflicts management | usBIM.clash | ACCA software
Merge into a single BIM | usBIM.clash | ACCA software
Filter and group
merge into a single BIM model in the IFC format, filter and group the entities for running a clash detection analysis
Set the clash parameters | usBIM.clash | ACCA software
Set clash parameters and interferences
set the clash parameters by checking collisions, minimum distances or tolerances and automatically detect interferences between the various models
Match Clash criteria | usBIM.clash | ACCA software
View the Collisions
get a list of objects that match the clash criteria and view the colliding objects with a simple click
Manage the life-cycle | usBIM.clash | ACCA software
Manage life-cycle of each collision
manage the life-cycle of each new collision by updating its status when new clashes occur
Export the results in many formats | usBIM.clash | ACCA software
Export results in BCF, PDF, XLS...
export the results in many formats and deal with collisions in any other BIM authoring
Coordinate the different designers | usBIM.clash | ACCA software
Coordinate on the cloud usBIM
easily coordinate the different designersand comply with the IFC openBIM standards, thanks to the BCF format and the integrated functions of BIM coordination software
BIM Clash Detection: definition, types and advantages
What is BIM Clash Detection and what advantages does it offer?
How many and what are the different types of clashes? Everything you need to know about clash detection to revolutionize your work procedures
What is BIM clash detection?
BIM clash detection is the process that identifies potential errors in the federated BIM model, allowing them to be solved during the design phase before construction process has even begun.
In BIM modeling there's not only one model, but different models for each discipline (structural, plant, energy, etc.)
Once the various AEC professionals, each for their own specific discipline, have finished their part of the design and systems sizing process, the resulting models are merged into a single federated 3D model in which it is possible to identify any conflicts before construction. And this is where BIM clash detection comes into the scene.
The main purpose of BIM clash detection is to identify the specific points where different models can overlap. Detection of BIM interference is an essential part of the BIM workflow and ensures that there are no problems in the model that may affect project delivery or costs.
Different BIM clash detection type
There are three main BIM clash detection types:
  • hard clash: elements of separate models that occupy the same physical space, such as a duct that crosses a beam;
  • soft clash or clearance clash: elements with incompatible parameters, such as two elements that are too close to each other for assembly or maintenance;
  • workflow clash (or 4D clash): temporarily inadmissible elements, such as a very voluminous element (which does not pass through the door) which must be positioned or installed before the walls and openings are built.
The advantages of BIM clash detection
The advantages offered by BIM clash detection are numerous, among the most important:
  • Reduction of reworks on site. Detecting interferences directly on the virtual 3D model reduces the number and extent of reworks to be performed on the "physical" construction site.
  • Greater precision in all phases. Without errors or missed deadlines due to unclear projects, safer and more efficient construction projects are achieved, reducing risks and material wastages.
  • Time and money savings. Interference detections, carried out during the design phase, help reduce potential problems during the construction phase, which therefore result in significant time and money savings.
Make better, faster and safer decisions!
Discover our BIM clash detection software
Looking for a desktop BIM clash detection software?
BIM Application in design conflict detection | usBIM.clash | ACCA software
Need to perform a clash check for interferences between different objects and BIM models?
Discover the power of usBIM.clash, install the clash detection tool on your PC and use it for free for 30 days.
Download usBIM.clash for free
Do you want to deal with your BIM clash detection tasks as an online app?
BIM clash detection online | usBIM | ACCA software
Is your PC starting to slow down or do you just prefer to use cloud-based apps?
usBIM.clash is now available as a web application, allowing you to manage BIM clash detection online without having to download anything. Register now and start using usBIM, the integrated system with applications and 10GB free storage.
Get free access to usBIM
How to run clash detection of BIM models created by different designers and software vendors | usBIM.clash | ACCA software
How to run a clash detection of BIM models created by different designers and software vendors
usBIM.clash is the clash detection BIM software on federated BIM models certified by buildingSMART international®.
It doesn't matter which design software you or your design and construction team use.
With usBIM.clash:
  • open and view BIM models or objects in the IFC standard format and also in many other 3D formats (.SKP, .DWG, .3DS, etc.)
  • perform BIM clash detection tasks on projects created with Edificius®, Revit®, ArchiCAD®, Allplan®, Tekla®, VectorWorks®, AutoCAD®, SketchUp®, 3D Studio Max® and many others.
Thanks to the BIM clash detection functions, you can start from a single federated model that integrates the different design aspects (architectural, structural, plant engineering, MEP clash detection, etc.).
Looking for a Clash Detection Software BIM?
Use it for free
Hard clash or soft clash? | usBIM.clash | ACCA software
Hard clash or soft clash? You choose the most suitable type of clash detection to perform on your BIM models
From the federated model, identifying clashes is an easy task with entities such as:
  • elements of separate models that occupy the same space (hard clash), for example a pipe duct that crosses a beam;
  • elements with incompatible parameters (clearance clash), such as two elements that are too close to each other for assembly or maintenance purposes.
Just define simple ruleset parameters (type of comparison, type of collision, tolerance values) to automatically check for interferences based on the required analysis type (hard clash, clearence clash, etc.) and the degree of precision that you want to get.
Use it for free
Find out how to detect conflicts identified by the BIM-based tool usBIM.clash
IFC entity selection groups and filters help you to set up powerful clash detection rulesets available whenever you want | usBIM.clash | ACCA software
usBIM.clash allows you to choose BIM models and the elements to be analysed with maximum flexibility.
You can select objects directly on the model (visually and graphically) or use advanced features such as "Selection Groups" and "Selection Filters" which allow you to specify the files and entities on which to perform conflict analysis.
Advanced features such as "Selection Groups" and "Selection Filters" allow you to specify the entities upon which to perform a geometry conflict analysis.
The chosen analysis criteria can be stored as a template and therefore used as a meta-process analysis that can be repeated each time on the updated models.
The Clash detection results are dynamically updated not only at every model change, or models that have already been analyzed, but also in case new BIM models are added.
Looking for a Clash Detection Program?
Use it for free
How to see clash Detections with clear and comprehensive reports | usBIM.clash | ACCA software
usBIM.clash provides an overall and concise picture of the entire set of conflicts, their state together with an overall view of the design phase evolution.
Detected clashes and interferences (Issues) are organized in an accurate but easy to read clash report with a matrix structure in which you can easily identify:
  • objects that collide
  • the type of collision found
  • the state of the conflict (date of verification, resolution, etc.)
Thanks to the dynamic link between Issues and BIM, you can immediately identify and visualize interfering objects directly in the model.
By clicking on the collision, usBIM.clash automatically brings you back to the IFC model entities involved and highlights the collision points.
Looking for a Clash Detection Platform?
Use it for free
Deal with Clash detection with BCF, PDF, XLS | usBIM.clash | ACCA software
Deal with Clash detection with BCF, PDF, XLS and resolve conflicts dynamically and collaboratively
With usBIM.clash, conflicts in the design process are managed collaboratively between the different designers involved.
Enrich individual issues with notes, comments and screenshots of conflicting objects and optimize the BIM clash detection procedure.
You can export the BIM clash detection report:
  • in the standard BCF (BIM Collaboration Format) of buildingSMART international®, in line with the IFC openBIM philosophy
  • in many other standard operating formats: PDFXML, HTML, CSV, XLSX.
Using the BCF standard, the individual BIM designer can view each issue, the elements affected by the interferences and any other useful information necessary to solve the problem in their BIM application.
Use it for free
Find out the design conflict detection and workflow clashes tool usBIM.clash
Integrate BIM validation and Clash Detection with the entire construction process | usBIM.clash | ACCA software
The entire collaboration process can be managed by integrating the BIM validation and clash detection with the usBIM BIM management system and the other BIM integration tools.
You can:
  • coordinate multidisciplinary project teams, professionals and companies located in different places and working with different software
  • engage in instant messaging sessions with advanced team working functions
  • organize online meetings and conference calls with work colleagues
  • Share BIM data, construction project documents and 3D models in the cloud
Use it for free
Sign in now for free
