BIM project management software
BIM project management software | usBIM.project | ACCA software
BIM project management software?
Here's the solution that allows you to deal with BIM and project management in a single integrated system...
Find out more
usBIM.project is an integrated application in usBIM (available soon)
Get free access to a complete range of online software and 10 GB cloud storage
Managing AECO projects can easily slip out of control due to fragmented communication, unclear plans, and resource management challenges.
With usBIM.project, you can meticulously plan every phase and achieve greater efficiency, collaboration, and control!
You can meticulously plan every phase and achieve greater efficiency, collaboration, and control | usBIM.project | ACCA software
Project Planning | usBIM.project | ACCA software
Project Planning
Define the work plan and resources needed for the BIM project by organizing it into "Phases" and "Tasks" and assigning respective responsibilities.
Time and Cost Control | usBIM.project | ACCA software
Forecast the timelines and budget required for each activity, and during execution, record actual times and costs.
Project Execution | usBIM.project | ACCA software
Project Execution
Upload project deliverables to the platform to have information readily available and effectively communicate with all stakeholders.
Collaboration and Communication | usBIM.project | ACCA software
Monitoring and Analysis | usBIM.project | ACCA software
Quickly compare forecasts and the actual execution of each BIM project activity in terms of time and costs using dashboards and forecast and execution graphs.
BIM in Construction Project Management | usBIM.project | ACCA software
BIM in Construction Project Management: better planning and control of the BIM process
usBIM.project allows you to reconstruct the folder structure in the CDE in one or more logical views of the project which show the activities, the managers, the execution times and costs.
The integrated structure of project management based on BIM allows an improved management of the design, construction and maintenance of both the digital model and the built asset.
The forecasting phase can be very detailed allowing to identify the matrix of responsibilities of the various professionals involved in the project, the activities that each individual must perform and the expected results to be achieved (documents, files, etc.) with a clear attribution of responsibilities and execution times.
Each member of the process is notified by the system in relation to their roles of responsibility within the process with direct personalized access to project activities.
Get started with usBIM
Discover the BIM software for project managers integrated in usBIM
Project management and BIM | usBIM.project | ACCA software
Project management and BIM: real-time data analysis and continuous control of timing and costs
Each BIM professional records the activities and uploads the results of their activities (files, models, documents, reports, etc.) to the CLOUD according to the indications provided for during planning.
Statuses can be assigned to each phase and activity to specify whether they are to-do activities, in progress, suspended, implemented, to be checked or already verified. Each status will be useful for filtering views of scheduled activities for specific analyses.
The recording of activities and costs of each manager automatically generates a time schedule of the performed activities. The final time schedule is dynamically compared with the forecast.
The comparisons between activity planning and execution generate alerts and comparison diagrams to have the continuous control of project progression.
Get detailed views of data in the forecasting and execution phases and a comparative framework between project and execution.
A dashboard shows activity costs, performances, committed resources and expenses determined during the forecast and execution phases, showing absolute value differences with percentages between the forecast and execution phase.
Discover the BIM construction management software integrated in usBIM
BIM project management as a quality and responsibility control system | usBIM.project | ACCA software
The list of events carried out at work by the various professionals involved always produces a clear and traceable picture of how the different activities progress and how they are carried out by each member of the BIM workflow.
The activities and responsibilities framework can be exported to Excel selecting a specific time period and a specific member of the process to carry out any sort of analysis.
Discover the BIM modeling project management software integrated in usBIM
Project management and BIM to manage the general information delivery plan and the BIM project management plan | usBIM.project | ACCA software
Project management and BIM to manage the general information delivery plan (MIDP) and the BIM project management plan
The integration between activity management and the information containers organized in the CDE , allows an effective management of the information delivery plan and of the order as required by ISO 19650.
Planning of information production during the design, execution or maintenance phases, by means of a detailed project management plan , allows to identify the best scenario for a correct breakdown of the information containers as organized in the CDE of a BIM collaboration platform.
Thanks to usBIM.project, you can create different processes with activities that explain how the containers relate to each other and the content that they must have.
The management view of usBIM.project, overlayed on the structure of the CDE containers, allows the operational implementation of the entire Building Information Modelling process, the collaboration, coordination, verification, revision and control activities, ensuring time, costs and quality of the entire information system.
Discover all the advantages of BIM in Project Management with usBIM
A BIM project suite for the BIM project coordinator | usBIM.project | ACCA software
A BIM project suite for the BIM project coordinator: the integrated system for BIM coordination and collaboration
usBIM.project is an application integrated in usBIM, the BIM management system for the digitalization of the engineering, architecture and construction sectors.
The integration of usBIM.project with usBIM creates an extraordinary BIM project suite to manage the BIM process with cloud based tools and functions:
  • view and manage the most widely used file formats in the construction sector [.IFC, .BCF, Revit (.RVT and.RFA), Edificius (.EDF), EdiLus, TerMus, CerTus-HSBIM, Point clouds (.LAS, .LAZ, .E57, .PLY, .PTS, .XYZ, etc.), GIS (.geoJson), AutoCAD (.DWG and .DXF)]
  • work on complex construction and infrastructure projects completely online using any device and from any location.
  • store, and always have your files at hand ready for your own use or for sharing with other stakeholders
  • collaborate in real-time with the design, execution and maintenance teams with online instant messaging and video conferencing tools
  • manage issues directly on your model
  • create a BIM data management system by integrating the 3D digital model with data and documents
  • coordinate work in real-time by modifying models, checking and correcting errors
  • federate different models and BIM objects even in different native formats
  • perform clash detection, code checking, comparisons, merge... and modify the model in the openBIM format
  • manage construction maintenance workflows and integrate BIM facility management software in an advanced manner into all other activities of the BIM process
The application of BIM in project management integrated in usBIM
How does BIM support project management?
Building Information Modeling (BIM) provides significant support to project management. Through 3D BIM models, it's possible to precisely plan each phase of the project, including timelines, resources, and budgets.
Integrated project management with BIM allows for:
  • properly implementing communications, coordination, and collaboration;
  • effectively using the Common Data Environment;
  • enhancing the efficiency of various teams tasked with building the information model's components.
By adopting the BIM methodology, all team members can collaborate in real-time on a shared model, improving communication and information sharing. This way, potential issues can be identified in advance and managed more effectively.
The construction project manager can monitor the project's status in real-time through the BIM model, enabling an immediate response to challenges and changes.
How does the integration of BIM and Project Management contribute to sustainability in construction projects?
The true value of Building Information Modeling lies in integrating project management processes with the construction information model, deliverables, and information management.
The integration of construction project management with BIM in the CLOUD reduces many risks associated with poor quality and design synchronization, outdated or inaccurate quantities, undefined work, unrealistic schedules, unplanned work, and incorrect cost estimates.
The integration of these two methodologies allows for more precise resource planning, contributing to more efficient material and energy management, reducing environmental impact, and promoting sustainability in construction projects.
Who should use BIM Project Management Software?
BIM Project Management Software is useful for all parties involved in construction projects, including architects, engineers, designers, builders, project owners, and even clients, as it enhances communication, planning, collaboration, and management, contributing to successful projects satisfying all parties involved.
Harness all the benefits of BIM for project management!
usBIM.project allows you to implement BIM project management by integrating the BIM methodology into the project management process and fully leveraging its advantages.
Clear Project Vision | usBIM.project | ACCA software
Keep track of phases, tasks, and project documentation (information exchanges, documents, information delivery plan, and BIM model attachments).
Improved Collaboration | usBIM.project | ACCA software
All stakeholders can collaborate in real time on a shared platform.
More Effective Budget Management | usBIM.project | ACCA software
Forecast activity timelines and costs and track actual spending during execution.
Meeting Delivery Deadlines | usBIM.project | ACCA software
Precisely plan activities and coordinate operations to reduce delays.
Real-Time Updates | usBIM.project | ACCA software
Real-Time Updates
Have up-to-date information accessible to all team members and manage changes more flexibly.
Long-Term Growth | usBIM.project | ACCA software
Long-Term Growth
Thanks to monitoring and data analysis, achieve better performance in future projects.
Sign in now for free
