BIM Objects
Component BIM objects | usBIM.library | ACCA software
BIM objects are fundamental elements of every architecture, design, engineering and MEP project.
With usBIM.library, you have an advanced online library of BIM objects with thousands of free resources always available in all usBIM applications and ACCA software solutions
Use it for free
Free online application integrated in usBIM
Get free access to a complete range of online software and 10 GB cloud storage
ACCA families and BIM content | usBIM.library | ACCA software
All the BIM objects you need to complete and enrich your projects, available online anytime, anywhere!
Access your objects library integrated into the usBIM cloud ecosystem | usBIM.library | ACCA software
Access your objects library integrated into the usBIM cloud ecosystem, always available from any device and with any ACCA software application
Choose and add objects to the model without any format | usBIM.library | ACCA software
Choose and add objects to the model without any format or software compatibility problems
Create and share your IFC openBIM object library | usBIM.library | ACCA software
Easily create and share your IFC openBIM object library
Video free BIM families | usBIM.library | ACCA software
More than just a catalogue of BIM objects to choose from but a library which is seamlessly integrated into the usBIM ecosystem to enrich your projects directly online
With usBIM.library, simplify your workflow and improve productivity with a comprehensive online library of objects perfectly integrated into the usBIM cloud service and also available in Edificius (coming soon with other software too).
Search and download BIM objects to enrich your projects with a single tool and directly online.
Access usBIM.library from your browser and with any device, publish and share your models with anyone across the entire online library.
No more wasting time moving from other libraries to your modeling software. Become more productive and simplify your workflow.
Use it for free
Use the online free BIM objects integrated in usBIM
Get all the BIM objects you need with access from any device and directly online
usBIM.library offers 2D, 3D objects, textures, material layers, furnishings, MEP objects, heat generators, photovoltaic structures, lighting appliances and much more.
The library is constantly updated and can be used directly online and from any device.
usBIM.library comes with different types of predefined libraries to manage:
  • proprietary file resources such as .BOL or REVIT;
  • openBIM elements in the IFC format.
From usBIM.library, easily choose from thousands of generic furnishings, architectural or plant solutions created by the best known brands and leading manufacturers for architects, engineers, builders and designers (Natuzzi, Smeg, Artzzi, Whirlpool, Caleffi, Vitra and many others).
In addition, you can create your own openBIM library by quickly importing any geometry in the various 3D file formats available on the market (OBJ, 3DS, DAE, DWG, etc.).
Use it for free
Use the free online BIM content library integrated in usBIM
Easily create and share your IFC openBIM object library | usBIM.library | ACCA software
With usBIM.library, create a library of openBIM IFC objects in a few simple steps.
All you need to do is:
  • import a 3D object in one of the available formats (OBJ, 3DS, DAE, DWG, etc.);
  •  insert classifications, properties and values to describe all the characteristics of the object;
  • convert it to IFC format and add it to the library.
Once you have created your IFC BIM object library, easily share it with anyone with a public link. usBIM.library is the right solution for:
  • manufacturers who want to create an openBIM object library and share it publicly on their own company website
  • groups of designers, engineering companies, companies that frequently use the same objects in projects and want to share them with the entire team to create the know-how of the company
  • companies that have offices located in the territory that want to share the object libraries with local headquarters designers or with external designers.
Use it for free
Use the online BIM library furniture integrated in usBIM
Brands and manufacturers available in the online BIM objects library usBIM.library
Artzzi
Artzzi
Bertazzoni
Bertazzoni
Bla station
Bla station
Cgaxis
Cgaxis
CGM
CGM
Cosmic
Cosmic
Deca
Deca
Dekker
Dekker
Extremis
Extremis
Fiora
Fiora
GameTextures
Game-Textures
Geniale
Geniale
Gervasoni
Gervasoni
Globo
Globo
Green Furniture Concept
Herman Miller
Herman Miller
Hewi
Hewi
Hitchmylius
Hitchmylius
HORM
HORM
Idealstandard
Idealstandard
Intra
Intra
Kare
Kare
Keystone Ridge Designs
iGuzzini
iGuzzini
KitchenAid
KitchenAid
Laura Meroni
Laura Meroni
Lekolar
Lekolar
Liebherr
Liebherr
Lofra
Lofra
Luazzu
Luazzu
Lumec
Lumec
Lumina
Lumina
Marelli
Marelli
Marshalls
Marshalls
Martinelli luce
Martinelli luce
Merillat
Merillat
Mora
Mora
Natuzzi
Natuzzi
Nola
Nola
NORR11
NORR11
Paini France
Paini France
Panda Kitchen
Panda Kitchen
Panzeri
Panzeri
Roca
Roca
Sala Bella
Sala Bella
Schuster
Schuster
Senia
Senia
Sierra
Sierra
Smeg
Smeg
Solzaima
Solzaima
Stolab
Stolab
Svedbergs
Svedbergs
Thosmoser
Thosmoser
Vitra
Vitra
Whirlpool
Whirlpool
A wide selection of Edificius BIM objects are also available in these formats .BOL (BIM Object Library) on the www.bimobject.com portal, the marketplace for the construction sector with over 2,000 brands of specialistic products.
Sign in now for free
