Scan to BIM software
Scan to BIM software | usBIM.scan2IFC | ACCA software
Make the scan to BIM process faster and more profitable than ever!
With usBIM.scan2IFC, finally create IFC models from point clouds quickly, with flawless results and no data loss.
Get free access to usBIM
usBIM.scan2IFC is a desktop application integrated into the usBIM ecosystem
and will be available soon.
Ask for more info
Get free access to a complete range of online software and 10 GB cloud storage
Process data for digital building information modelling with scan to BIM | usBIM.scan2IFC | ACCA software
Scan to BIM is a process that allows you to easily capture the essential data of any space and transform it into a digital model useful for the design, monitoring and management of buildings.
With usBIM.scan2IFC, optimize the process by creating an IFC format model of the existing asset that is so accurate and faithful to reality contributing to eliminating the risk of losing any data in the transition to any BIM modeling software.
Video of usBIM.scan2IFC, from point cloud to IFC 3D model | ACCA software
From the point cloud to the IFC model in total freedom | usBIM.scan2IFC | ACCA software
with 100% openBIM workflows
From the point cloud to the IFC model at maximum speed | usBIM.scan2IFC | ACCA software
with advanced automatic recognition features
From the point cloud to the IFC model with the utmost detail | usBIM.scan2IFC | ACCA software
thanks to specific functions to add and customize IFC properties
From the point cloud to the IFC model without BIM authoring software for 100% openBIM workflows | usBIM.scan2IFC | ACCA software
In the process of creating the BIM model from a point cloud, openBIM and interoperability become essential because the data and the 3D model must be accessible to a series of different figures (from the historian, conservation operators, designers, to visitors) and usable throughout the life of the building.
With usBIM.scan2IFC, generate BIM models in the IFC openBIM format starting from a point cloud loaded on usBIM without and having any BIM authoring software.
The obtained IFC model gives life to 100% openBIM workflows in which:
  • the professionals you work with are free to use any software to produce, read and manage data;
  • data is always accessible over time without a licence to use the software
  • the information contained in the BIM model is readable and analysable by anyone because it is shared in an open format and not in proprietary formats controlled by individual suppliers.
Get started now for free
Try the one of the best scan to BIM software
Automatic recognition functionality to quickly reconstruct the BIM model from the point cloud | usBIM.scan2IFC | ACCA software
usBIM.scan2IFC has special features that allow you to build BIM models using the point cloud for guidance without needing to rebuild the architectural model from scratch.
Thanks to special detection tools, in just a few simple steps, it is possible to reconstruct:
  • the Height Reference System (HRS)
  • the building envelopes
  • doors
  • windows
  • rooms and compartments
  • rooftops
The process of reconstructing the BIM model from the point cloud becomes much faster, more precise and accurate, guaranteeing results that are extremely faithful to the real object.
Discover how to improve the Scan to BIM workflow integrated in usBIM
From point clouds to increasingly detailed IFC 3D models thanks to specific functions to add | usBIM.scan2IFC | ACCA software
From point clouds to increasingly detailed IFC 3D models thanks to specific functions to add and customize IFC properties
usBIM.scan2IFC allows you to create extremely detailed 3D IFC models from point clouds.
You have specific functions available that allow you to add and customise the IFC properties of the elements that make up the model and all with a few simple clicks.
In addition, with usBIM.scan2IFC, you can automatically get:
  • drawing models (plan views, cross-sections, elevation views, etc.)
  • isometric views
  • working drawings
  • photorealistic renderings
Thanks to its powerful functions, usBIM.scan2IFC is the perfect tool for anyone who wants to create openBIM workflows with accurate 3D models of their projects.
Try the 3D scan to BIM software
What you need to know about Scan to BIM
Scan to BIM is a process that, with the help of advanced surveying techniques, allows you to create the 3D digital model of a built environment.
Thanks to this process, it is possible to digitize any building and make it accessible to the use of Building Information Modeling (BIM), an indispensable tool to better plan renovation interventions, to carry out Facility Management activities and, more generally, to manage the entire life cycle of the building.
The Scan to BIM process allows you to capture accurate scan data in the form of a building information model (BIM). In order for the scan data to be imported into the model quickly and accurately, it is essential to have files in IFC format. Using IFC files in the scan to BIM process ensures that the scan data collected is as accurate and efficient as possible. The IFC format, in fact, is a globally recognized and supported open file format that allows architects, engineers and contractors from anywhere in the world to easily collaborate on a project.
Creating a Scan to BIM process with IFC files:
  • ensures the consistency of the design process from start to finish;
  • ensures that all parties involved have access to accurate scan data;
  • reduces the time required by complex manual processes.
The "Scan to BIM" process allows you to move from laser scanning to the BIM model of an existing building. This process begins with the acquisition of building information through the use of laser scanners. Through the data collected from the scanning campaign you can get a 3D visualization of the building called the "point cloud" which, with specific BIM authoring software, can be converted into a BIM model.
A Scan to BIM workflow allows you to overcome problems that would not be possible to address using traditional surveying methodologies. The biggest problem that Scan to BIM can solve is the acquisition of geospatial information in remote places or in the presence of natural or artificial obstacles.
Among the main benefits of the Scan to BIM process we have:
  • more accurate representations of existing environments;
  • reduction of BIM modeling errors;
  • considerable reduction in scanning times of buildings compared to traditional survey methods;
  • saving of money and resources related to reducing processing times
Sign in now for free
