RVT viewer
Looking for a free RVT file viewer?
Here's a free RVT viewer to open RVT files and BIM models directly online in various different formats (IFC, DWG, EDF, DXF)
RVT file viewer | usBIM | ACCA software
Get started now for free
Discover the Revit file viewer online integrated in usBIM.
Get free access to a complete range of online software
and 10 GB cloud storage.
Here's how to view your RVT files for free!
Login to usBIM with your ACCA account | usBIM | ACCA software
Load your RVT files with a simple Drag&Drop | usBIM | ACCA software
Now you can view them using the free RVT viewer | usBIM | ACCA software
Discover the RVT viewer online online integrated in usBIM.
What is a RVT file | usBIM | ACCA software
What is a RVT file?
The .RVT file extension, is typically created by Autodesk's Revit® software. It's a BIM architectural design file based on 3D models that provides architecture, engineering and construction professionals with the information and tools to plan, design, build and efficiently manage construction and infrastructure works.
RVT files contain 3D models of the project together with the related technical information such as dimensions, costs, geometric data, etc.; moreover, the 3D model also allows the user to produce the entire set of construction documents, such as floor plans, elevations, sections and many other types of architectural drawings useful for presenting the project to the client.
Do you need to open RVT file online for free?
Use the free RVT viewer online now
How can I open a RVT file online | usBIM | ACCA software
How can I open an RVT file online?
Whatever the format of your project's 3D model, RVT, DWG, IFC, DXF, EDF, etc., you can view and manage it with a free RVT reader like usBIM.
You can use RVT viewer and open RVT files without worrying about installing any software on your PC, nor the Revit program with which the file was created.
usBIM has a high-performance RVT file viewer that allows you to view the contents of an RVT file and many other file formats, whether proprietary or not, using a simple browser and, above all, using any device (a PC, tablet or smartphone).
In general, programs that open 3D files can end up losing out in terms of performance and require long processing times due to the huge amount of information and model complexity. With RVT viewer, you can finally solve that problem and quickly open an RVT file online!
All you need is an ACCA account that allows you to access the usBIM service page and with a simple drag&drop, upload and view your RVT file with great power!
Do you need to view Revit file online for free?
Use the free RVT file reader online now
usBIM is the online viewer for viewing 3D models and technical files of any size and many different formats
View your construction and infrastructure projects in the IFC, DWG, DXF formats and over 100 other types of technical files using a simple web browser and from any device or operating system.
IFC fileDWG fileDXF filesREVIT FileSKP fileSVG fileGEOJSON FileLAS File
Sign in now for free
