BIM Software / usBIMusBIM Explore Free Apps usBIM.browser BIM viewer usBIM.pointcloud Point cloud Viewer usBIM.federation BIM federated model usBIM.gis BIM-GIS software usBIM.bcf BCF management usBIM.library BIM Objects PriMus online BoQs & Price Lists All free apps Additional Apps usBIM.clash BIM Clash Detection usBIM.checker BIM validation usBIM.editor Advanced IFC editor usBIM.reality Construction in Metaverse usBIM.project BIM project management usBIM.planAI 2D to 3D/BIM usBIM.IoT BIM IoT Platform usBIM.blueprint Technical Construction Drawings usBIM.scan2ifc Scan to BIM software All Additional Apps Platforms usBIM BIM Management System usBIM.platform Common Data Environment usBIM.bridge Bridge Management usBIM.dossier Engineering document management usBIM.resolver Construction management software usBIM.maint Facility management software usBIM.geotwin Geospatial Digital Twin Solutions IFC viewer online BIM Coordination BIM Collaboration BIM Data Management Get Support Technical support User Manual File formats supported Compare usBIM/usBIM.platform Learn Try for free Buy Compare 3D modelsDo you have two versions of a 3D model in the IFC file format and need to quickly see the differences?Discover usBIM.compare, just a few simple clicks to compare different versions of your IFC models and identify geometric and informative differences in detailFind out more Get started now for freeusBIM.compare is an integrated application in usBIMGet free access to a complete range of online software and 10 GB cloud storage Keeping track of all changes made to an IFC 3D model can be difficult, especially if multiple people are working on itusBIM.compare is the solution to compare and evaluate IFC file revisions in a few simple steps!Get started now for freeDiscover the 3D model compare integrated in usBIM Follow the online courses for rapid software learning How to compare two 3D models in IFC format in a few simple stepsComparing two 3D models in IFC format is quick and easy with usBIM.com!Discover how it's done in 5 simple steps: create a new comparison file in the usBIM cloud service; choose the 3D IFC model that you'd like to analyse; choose the IFC versions for the comparison; start the calculation process for comparing files; view the geometric and information differences detected directly on the model.How to compare 3D models?Get started now for freeQuickly identify differences between two versions of an IFC file and assess the impact of changes on the entire projectusBIM.compare allows you to view the changes directly on the BIM model highlighting any differences detected with different colors.This powerful but simple method allows you to see how the new version differs from the original version used as a reference.In addition, at each comparison usBIM.compare generates an objects classification composing the model being assessed dividing them into: Added: specifies the number of items added in the comparison version that were not present in the reference version; Removed: specifies the number of items removed in the comparison version that were already present in the reference version; Changed: specifies the number of elements changed in terms of geometry, position and properties; Unchanged: specifies the number of elements that, during the design phase, have not undergone any geometric and/or informative changes.This gives you a clear idea of the impact of any changes on the project. Get started now for freeUse the 3D model comparison integrated in usBIMQuickly and intuitively compare the two versions of the IFC file with viewing filtersTo analyze the differences between the two versions, select the object directly from the model or use special viewing filters to analyze the elements based on: status; global ID; element type or name; changes found between "old" and "new" versions of the 3D model in IFC format.Reading the comparison calculation results between two versions of the IFC file turns out to be much faster and the useful colour mapping and highlighting allows for better reading of detected object changes directly on the BIM model! Get started now for freeDiscover the functions to compare 3D modelsEasily compare the IFC property values of the new and previous model and identify all variationsWith usBIM.compare quickly compare the property sets of two versions of the same IFC file. Once the comparison is started, the software generates an intuitive table with all the IFC properties for the previous and the current model. This allows you to keep track of the changes made.In this way usBIM.compare offers a complete view of the changes made to a 3D model in IFC format through: a visual comparison of the geometric differences directly on the 3D model a list of the IFC properties that have changed.How to compare two 3D models?Get started now for freeExport and share the comparison results in standard formatsOnce the geometric and informative differences between the two IFC models have been detected, with usBIM.compare you can export the comparison results relating to the file versions: in the standard format .BCF (BIM Collaboration Format) a buildingSMART international ® standard; or in the formats .CSV and .XLSEasily save the comparison document to the cloud and share the contents with other members of your team, even using usBIM instant messaging system. How to compare 3D BIM models?Get started now for free Testimonials What they say about us Project Interview more information.. Find out more × FAQWhat is meant by comparison of two 3D models? Two 3D model comparison is a process of identifying and analyzing the differences between two different versions of a 3D model. These variations may relate to geometric, informational or structural aspects of the model, and are highlighted to understand how the two versions differ from each other.Why should you make a comparison between two versions of the 3D model?Comparing two versions of the 3D model helps to: identify the changes made between versions, providing a clear view of the differences; assess the impact of the changes on the project and ensure that all parties involved are aware of the revisions; maintain the accuracy and consistency of the design.To compare two versions of a 3D model, you just need to: upload both versions in usBIM.compare; perform difference analysis between the two versions of the IFC BIM model, using the available comparison tools; view highlighted changes, such as geometric, informational, or structural differences, directly on the model (added, removed, changed, and unchanged); evaluate the impact of the changes and make informed decisions based on the results of the comparison.To learn more about the steps involved in comparing different versions of the 3D model, you can read the article "How to detect changes in IFC models" which explains in detail how to use usBIM.compare.How to compare 3D models?To compare two versions of a 3D model, you just need to: upload both versions in usBIM.compare; perform difference analysis between the two versions of the IFC BIM model, using the available comparison tools; view highlighted changes, such as geometric, informational, or structural differences, directly on the model (added, removed, changed, and unchanged); evaluate the impact of the changes and make informed decisions based on the results of the comparison.To learn more about the steps involved in comparing different versions of the 3D model, you can read the article "How to detect changes in IFC models" which explains in detail how to use usBIM.compare.How to identify differences between two versions of an IFC file using usBIM.compare?usBIM.compare highlights the differences directly on the BIM model using different colors for each type of change. It also generates a classification of objects, indicating elements that have been added, removed, changed, or remained unchanged.Can I compare IFC property values between the new and the old model using usBIM.compare?Yes, usBIM.compare allows you to quickly compare the property sets of two versions of the same IFC file. The software generates an intuitive table with the values of all IFC properties for the old and new models, allowing you to keep track of changes made. usBIM, the BIM management system, scalable and configurable according to your needs.Get started with applications and 10GB of cloud storage space for free. Then choose the applications that you need to configure your usBIM experience according to your preferred workflow! usBIM is the online system that integrates different types of BIM tools: BIM interoperability tools: allowing full interoperability during the various phases of construction design, execution and the relating maintenance processes BIM collaboration tools: specific BIM tools for improved collaboration and sharing of information among all the various stakeholders involved in creating or updating the digital twin during the project's entire life cycle. With usBIM, manage the project, construction management and maintenance phases of a building or infrastructure, starting from the free usBIM solution. usBIM offers you infinite configurations with functions, applications and cloud storage space that you can activate from the online store. Only subscribe to the BIM tools that you really need. Keep your usBIM tools under control. Check out your current configurations and remain updated with the latest available plugins.Sign in now for freeAPP and functions provided with usBIM (included and free of charge) usBIM.browser BIM Viewer usBIM.pointcloud Point cloud viewer usBIM.federation Federations of BIM models and Point Clouds usBIM.chat Online chat and messaging service usBIM.meet Video Meetings and desktop sharing tools usBIM.gis BIM-GIS software usBIM.bcf BCF (BIM Collaboration Format) management usBIM.writer Integrated Word Processor for document and forms management usBIM.office Microsoft Office document editing usBIM.media Web Media Player usBIM.calendar Online Calendars PriMus online (light) Online construction cost estimating software usBIM.bSDDeditor bSDD Editor usBIM.IDSeditor IDS Editor usBIM.library BIM Objects usBIM.revolution Revit® openBIMAvailable SoonAPPs and additional functions (available with subscription plans) usBIM.clash BIM Clash Detection usBIM.gantt BIM 4D software usBIM.checker BIM validation usBIM.refactor Refactoring and Merge IFC files usBIM.editor Advanced IFC file editor usBIM.IoT BIM IoT Platform usBIM.render Online 3D renderingAvailable Soon usBIM.reality Construction in the Metaverse usBIM.facility BIM Facility Management usBIM.project BIM project management softwareAvailable Soon usBIM.blockchain BIM-Blockchain integration usBIM.compare Compare 3D Models PriMus online Online construction cost estimating software usBIM.bSDD buildingSMART Data Dictionary usBIM.IDS Information Delivery Specification usBIM.blueprint Technical Construction Drawings usBIM.land BIM Google maps®Available Soon usBIM.BI BIM Business IntelligenceAvailable Soon usBIM.scan2IFC Scan to BIM softwareAvailable Soon Integrated platforms (available with subscription plans) usBIM.platform Common Data Environment Software usBIM.dossier Engineering document management software usBIM.resolver Management construction site problems usBIM.maint Facility Management Software usBIM.firemaint Fire protection maintenance software usBIM.planAI 2D to 3D/BIM usBIM.bridgeBridge management software usBIM.geotwin Geospatial Digital Twin Read Building Information Modelling openBIM vs closed BIM BIM construction IFC and openBIM® openBIM standardExplore Digital Twin software 3D point cloud Structural health monitoring software Bridge inspection software Virtual reality software Snag list software Punch list software GIS asset management softwareTry BIM Viewer Point cloud viewer DXF viewer DWG viewer RVT viewer SKP viewer LAS viewer 3D viewer
