Using usBIM.browser brings many advantages in the work of technicians, speeding up and simplifying both ordinary and more complex operations. In fact, with a free application, it is possible to have a very powerful tool to manage and navigate even large files, generated with any BIM authoring and without installing any specific software. This means that with usBIM.browser you can easily browse models created with Revit (or any other BIM software) even without having Revit on your computer.
You can browse any type of 3D file: architectural, structural models, plant engineering and ranging from large to small scale without problems and with any device. In addition to viewing the model, you can also query each element or attach information and data to create a real set of files linked together in advanced and complex models but managed with extreme simplicity.
Being browser based, you can view files using any device. In this way you can consult your work files while you are on the train, on the construction site or at a customer's home, even using your tablet or a simple smartphone.
You can manage large files without taking up space on your PC and share your work with extreme simplicity and speed.
You can collaborate with your colleagues and exchange models and files even if you don't use the same software.
