Advanced IFC editor
Advanced IFC editor | usBIM.editor | ACCA software
Looking for an IFC editor that allows you to work on an IFC file without Revit®, ArchiCAD®, Edificius...?
Now you can with usBIM.editor!
Use it for free online
Try it for free for a month; then choose the subscription plan that suits you best.
Free IFC editor for a month | usBIM.editor | ACCA software
With usBIM.editor, working with IFC files and editing IFC models, allows you to manage information and access data with great freedom throughout the construction lifecycle without having to use the same software used to create the original architectural model…. That’s true BIM collaboration freedom!
Video online IFC editor | usBIM.editor | ACCA software
Open IFC files | usBIM.editor | ACCA software
Open IFC files regardless of the BIM Authoring software used during their creation (Edificius®, Revit®, ArchiCAD®, ALLPLAN®, Tekla®, EdiLus®, etc.)
IFC Editor | usBIM.editor | ACCA software
View and operate on the entire model and on the individual IFC entities and properties
Library of BIM objects | usBIM.editor | ACCA software
Access an extensive library of BIM objects to enrich your model or even create new IFC objects
Online IFC editor | usBIM.editor | ACCA software
Is your PC starting to slow down or do you just prefer to use cloud-based apps?
Use the usBIM.editor application to edit, export and view files in the IFC format directly online and without having to download and install any applications.
Get free access to usBIM
Edit geometric and informative properties of BIM models | usBIM.editor | ACCA software
Edit geometric and informative properties of BIM models: all with a single advanced BIM editor
With usBIM.editor, work on IFC model files created with any BIM authoring not only through basic functions for viewing and navigating the IFC model but also with advanced editing functions too:
  • navigate through the model based on property and classification selections
  • move and rotate 3D models taking advantage of different viewing options (transparency levels and different element colour maps)
  • edit, delete, replace and add geometric and data properties for each individual entity
  • customise attributes, properties and classifications
  • delete and move one or more objects directly on the BIM model
  • define custom classification schemes
  • create a new version of the IFC model with all the geometric and informative changes made to the original model
Use it for free
BIM editor free for a month
Customize your IFC model with additional 3D objects | usBIM.editor | ACCA software
Customize your project with new 3D objects: acquire them from the online library
With usBIM.editor, enrich and make the IFC BIM model more realistic with high-definition objects thanks to the integration with usBIM.library, the library integrated into the usBIM ecosystem and accessible from all its online applications.
With usBIM.library, get your hands on thousands of free objects ready to be added to the model.
Manage the added elements by arranging them in the model's IFC structure by assigning them with a class.
Use it for free
IFC editor free for a month
Real-Time collaboration with your team directly on the model ready for sharing it on the usBIM cloud | usBIM.editor | ACCA software
The online version of usBIM.editor allows you to collaborate in real-time with your team members viewing them as avatars connected live to the model.
In addition, share the model on the cloud by taking advantage of the BIM management system integrated with the usBIM ecosystem.
With usBIM, in addition to your free 10GB of storage, you also get access to free apps for:
  • manage the most commonly used file formats in the construction industry [.IFC.BCF, Revit (.RVT and.RFA), Point Clouds (.LAS, .LAZ, .E57, .PLY, .PTS, .XYZ, ecc.), GIS (.geoJson), AutoCAD (.DWG and .DXF)]
  • coordinate multidisciplinary project , professionals and companies located in different places and working with different software solutions
  • engage in instant messaging sessions with advanced team working functions
  • organize online meetings and conference calls with work colleagues
Use it for free
Edit IFC files free for a month
FAQ BIM Editor
The IFC (Industry Foundation Classes) is an open data format, not controlled by a single operator, created to allow interoperability between the various actors in the building process. It aims to allow the interchange of an information model without loss or distortion of data or information. It contains various types of information (geometric data, properties, relationships with other objects).
Il contient des informations de différents types (données géométriques, propriétés, relations avec d'autres objets).
You may need to modify an IFC file for several reasons:
  • need to change, add or delete some entity properties (e.g. change the transmittance value of walls because of errors or because of a design variation or changes in the surveyed de-facto situation);
  • need to add, move, modify or delete objects from the IFC model without going through the BIM authoring tool (e.g. delete a wall that has been removed in the works variation project, or a change in the position of furniture, etc.).
Because usBIM.editor allows you to open, view and edit IFC models by operating on the geometry and properties of each individual entity. In this way, you work directly on non-proprietary open formats and without the need for specific BIM authoring.
usBIM.editor is also a model viewer:
  • open IFC files created by any BIM software;
  • view and navigate the model;
  • edit, delete, replace and add objects and properties;
  • import and export property templates in the Excel format;
  • export the IFC model with all modifications integrated.
With the usBIM.editor you can edit both the geometry and the IFC file entity properties.
This is thanks to the two dedicated environments in the software:
  • BIM model - you can make changes to the geometry of elements, insert new models, assign materials;
  • Editor IFC - you can edit, delete or add information to the model entity properties.
Yes, after editing your IFC with the usBIM.editor, you can export the file and generate a new IFC that retains all the changes made.
Sign in now for free
