IFC VIEWER Online
Free viewer IFC online | usBIM | ACCA software
Looking for a high performance and free online IFC viewer to view and manage BIM models of any size?
With usBIM you can always view and share construction and infrastructure projects in the IFC file format and in many other technical formats such as Revit, DWG/DXF, Point Clouds, GIS, 3D, Office, PDF... Power and performance never seen before!
Try the viewer  Get started for free
Get free access to a complete range of online software and 10 GB cloud storage
All the advantages of the online model viewer usBIM
A multi-format viewer for IFC, DWG, DXF, Revit files in all in one free web platform for the higher performance and efficiency even when working with large sized files of buildings and infrastructures
View, federate and manage your 3D BIM models online | usBIM | ACCA software
View ifc files online, federate and manage your 3D BIM models online in various different formats with the capability of processing large sized files (online IFC file viewer, DWG viewer, Revit viewer, DXF viewer, etc.)
IFC viewer web to share BIM models with anyone | usBIM | ACCA software
Share BIM models with anyone and always have them at hand everywhere without having to continuously copy, duplicate, send any files and without the need to install or update any software
Create and share a customized BIM Object Library| usBIM | ACCA software
Create and share a customized BIM Object Library, with files in any format and together with an integrated file versioning system
View the 3D BIM model | usBIM | ACCA software
View the 3D BIM model, or IFC in Real-Time Rendering, Augmented Reality and Virtual Reality online
usBIM is the online viewer for viewing 3D models and technical files of any size and many different formats
View your construction and infrastructure projects in the IFC, DWG, DXF formats and over 100 other types of technical files using a simple web browser and from any device or operating system.
IFC fileDWG fileDXF filesREVIT FileSKP fileSVG fileGEOJSON FileLAS File
Do you often end up losing important project documents when you need them most?
Increase your freedom and productivity. Use usBIM for free!
Always have project documents at hand ready for you to consult from anywhere | usBIM | ACCA software
Always have your project documents at hand ready for you to consult from anywhere
Easily show project to your clients using any device | usBIM | ACCA software
Easily show your project to your clients using any device
Share projects in real-time and become more engaging with colleagues | usBIM | ACCA software
Share your projects in real-time and become more engaging with your colleagues
Try usBIM.ifc5, the revolutionary and free IFC5 viewer
The platform designed to support the transition to the new IFC5 format, which goes far beyond the simple concept of a viewer.
With usBIM.ifc5 ACCA provides a state-of-the-art tool that contributes to the testing and implementation phase of the new standard, offering a comprehensive set of advanced functionalities for visualising and managing digital models in IFCX format.
  • Conversion of existing models to the new IFC5 format (.IFCX) is only the starting point.
  • Non-destructive editing, with secure and traceable changes to models that maintain the integrity of the original data.
  • Simultaneous editing for collaborative project management and distributed team work on the same models.
  • Integration with GIS systems.
  • Advanced management of model federations of any scale and complexity.
  • Analysis of spatial boundaries (space boundaries) and the management of infrastructural elements such as geotechnical soundings (borehole).
  • Dedicated forum for sharing feedback and experiences enables collaboration between all users of usBIM.ifc5.
The platform will be continuously updated and made available throughout the definition phases of the new IFC5 standard
Try usBIM.ifc5
Read more about the IFC5 format
Video viewer IFC5 | usBIM.ifc5 | ACCA software
Open and view tons of 2D and 3D design file formats online | usBIM | ACCA software
Open and view tons of 2D and 3D design file formats online... managing large file size models on the web with a high-performance viewer!
With usBIM you can open files, view and browse through your files, documents and models in multiple digital file formats:
  • BIM: IFC, BCF, Revit (.RVT and .RFA), Edificius (.EDF), EdiLus, TerMus, CerTus-HSBIM
  • Point clouds: .LAS, .LAZ, .E57, .PLY, .PTS, .XYZ, etc.
  • GIS: geoJson
  • CAD: AutoCAD (.DWG and .DXF)
  • 3D: Sketchup (.SKP), collada (.DAE), .OBJ, etc.
  • Images: .JPG, .BMP, .PNG, etc.
  • 360° Photo: .JPG, .JPG360
  • Others: .PDF, Office (.DOCX, .XLSX, .PPTX, etc.)
See all the file formats supported by usBIM
With usBIM you can seamlessly process and work with large files that probably no other web IFC viewer can handle and with absolutely extraordinary speed and performance!
Get started with usBIM
Discover the IFC file viewer online integrated in usBIM
Manage IFC, DWG / DXF, PDF and Office files online | usBIM | ACCA software
Manage IFC, DWG / DXF, PDF and Office files online , share them or keep them with you wherever you go
With usBIM you have a free cloud storage space that you can easily arrange in folders and a revolutionary high-performance IFC model viewer online capable of managing even the most complex of files helping you to concentrate on the things that count… your work and online collaboration needs.
Access the files and folders you upload to the cloud via the ifc web viewer’s functions with any device and from any location (office, construction site, home, etc.) all with just a simple browser and without installing any software application.
The IFC file viewer online works like a web app on Android, iPad, Mac or Windows; freely use different software and file formats BIM, CAD, Point Clouds, GIS, 3D, OFFICE, PDF (DWG, IFC, RVT, EDF, etc.).
View files of buildings and other types of constructions (roads, bridges, railways and all kinds of infrastructures) in 2D and 3D.
With usBIM you always have your ifc data, your documents and BIM models with you ready on a viewer app to share with them with team members and collaborators, groups or with a public link on a website, blogs, or social networks, etc.
Discover the Web IFC Viewer integrated in usBIM
Work with project files and with properties of your IFC entities online using advanced management tools | usBIM | ACCA software
Work with your project files and with the properties of your IFC entities directly online using advanced management tools
With usBIM you can upload IFC and BIM files and manage them directly online. The most advanced features include the below:
  • view, organize, search or filter with advanced functions to access all the information contained in a BIM model, of an IFC or Revit file
  • select individual model federations or objects of each model
  • you have several viewing options for moving, rotating and scaling
  • federate models and BIM objects in different native file formats
  • create a mix of digital objects and information, documents (PDF, DWG, DXF, Word, Excel, etc.) and data
  • create links to drawings, documents and information from the BIM
Discover the free online IFC viewer integrated in usBIM
Create and share BIM libraries | usBIM | ACCA software
With usBIM you can convert the BIM objects file format (such as IFC, RVT, RFA, BOL, etc.) and other graphical objects (such as DWGs, DXFs, OBJs, SKP files, etc.) into other formats to generate new objects.
View by categories, apply filters and do advanced searches to find BIM objects shared with collaborators during the design, execution or maintenance phases of the construction industry.
Discover the IFC reader online integrated in usBIM
Experience 3D BIM model with advanced Architectural Visualization functions online | usBIM | ACCA software
Experience your 3D BIM model with advanced Architectural Visualization functions directly online
With usBIM.render and usBIM.reality – the two applications that can be activated with a subscription from usBIM.store - you can experience your 3D BIM models live and directly online with advanced rendering, real-time rendering or immersive virtual reality tools.
You can see the 3D BIM model fully rendered with materials, shadows and lighting effects that make your model hyper realistic.
Communicate and present your project, inform and train in an absolutely innovative way, even with public links to use on webpages, blogs, social networks, etc… make your IFC models accessible to everyone.
You have a very advanced and high-performance visual control over the quality of the project and on any critical issues that need to be addressed with your colleagues.
Do you need to open IFC file online?
Did you know that with usBIM, not only can you view your IFC files online but you can edit, print, render and visit your BIM model in a virtual reality viewing experience?
With usBIM.editor, you can work on an IFC file without using Edificius®, Revit®, ArchiCAD® or other BIM Authoring tools...
Find out more
IFC Viewer Online FAQ
An IFC file is an open, non-proprietary file format that enables interoperability and data exchanges without errors or loss of information. It is therefore the common language that allows the different actors of the construction process to dialogue with each other.
A fundamental characteristic of BIM, in fact, is the collaboration between the different professional roles involved in the different phases of a building or infrastructure's life cycle to insert, extract, update or modify the model's information.
With usBIM you can open and view IFC 2X3 files of any type produced with the different BIM authoring solutions available on the market; you can also open other types of 3D files (.skp, .dwg, .dae, etc.) converting them to the IFC format.
Yes, usBIM also has advanced BIM model creation and editing features.
usBIM also allows you to add properties to IFC files in order to enrich the existing information with additional technical, commercial, structural, plant, measurement and many other types of data. And this is possible without the need for any BIM authoring software.
Sign in now for free
