BIM issue Management
BIM issue management tool | usBIM.resolver | ACCA software
Do you want to manage and track every BIM issue?
Turn your BIM issues into activities and follow them until they are resolved with a platform for tracking BIM issues tracking platform
Use it for free Check out the offer
Activate one year free trial on usBIM.store
Get free access to a complete range of online software and 10 GB cloud storage
With usBIM.resolver, solve all BIM issues thanks to a powerful BIM issue tracking system
  • identify BIM issues from BIM model federations, clash detection or any other stage of the BIM process
  • manage BIM issues in the BCF format (BIM collaboration format)
  • turn project errors and problems into tasks
  • assign activities to those responsible for their resolution
  • follow errors and problems until resolution
  • get a quality BIM process and coordination
Use it for free
Try now the BIM issue tracking software usBIM.resolver and reduce the duration of your projects by 50% or more!
During the clash detection phase, did you end up with any physical interference problems between a fixture and a pillar?
Is the installation or construction of two objects designed with an incorrect works sequence?
Do these kind of problems sound familiar to you?
Find out how usBIM.resolver helps you solve these and other issues related to BIM issue management in just a few simple steps!
Create activities and quickly communicate the BIM issues to be resolved | usBIM.resolver | ACCA software
The BIM managers and the BIM coordinator are responsible for communicating with the design teams to better manage the resolution of problems encountered during clash detection or code checking.
With usBIM.resolver you communicate and assign the identified issues in an extraordinarily clear and efficient way.
Does that satisfy your need for identification?
  • transform each problem to be solved into a planning card;
  • indicate the level of urgency, the deadline, the activities to be carried out and the persons responsible.
The planning cards will show all the information the team will need so that everyone knows exactly what to do without leaving room for any misunderstanding.
Use it for free
Discover the BIM issue tracking program integrated in usBIM.resolver
Add all documents needed to resolve BIM issues | usBIM.resolver | ACCA software
To ensure coordination and communication between different professionals, the BIM manager or BIM coordinator must share all the information necessary to resolve the issue.
With usBIM.resolver you share all this information directly in the reference task and make sure that those who have to solve the interference encountered can access this data directly from the activity created, without having to search among files and information contained in other archives, everything is immediately reachable with a click!
Each person involved will have a complete view of the different issues identified that can be accessed simply using a browser, regardless of the BIM authoring software used.
usBIM.resolver is integrated into usBIM, the BIM management system that maximizes collaboration and allows you to federate hundreds of models and view any type of file (DWG, DXF, EDF, RVT, IFC,  PDF, Doc), making communication and coordination between the different disciplines free from the constraint of having to use the same software.
Use it for free
Discover the BIM issue tracking system integrated in usBIM.resolver
Trace the entire process of managing an issue | usBIM.resolver | ACCA software
BIM issue management is a crucial part of any BIM project as it helps address any interference before it becomes serious.
With usBIM.resolver you manage the entire BIM issue tracking process in an easy and intuitive way.
The BIM issue management is compatible with the BCF standard format and therefore can be performed respecting all the principles of openBIM or through integration with proprietary BIM Authoring platforms and software.
In addition, with visual planning cards everything is clear at a glance: who is working on what and when things will be done.
usBIM.resolver becomes a real hub where to track and monitor the critical issues of the project until they are closed. In this way, you follow the progress of the problem resolution and have full control of the project.
In addition, the BIM issue management process is compatible with the BCF standard format and therefore can be performed respecting all the principles of openBIM or through integration with proprietary BIM Authoring platforms and software.
Use it for free
Discover the BIM issue resolver integrated in usBIM.resolver
Solve BIM issues faster and reduce your project time by 50% or more!
Use it for free
Discover the BIM issues tracking platform integrated in usBIM.resolver
usBIM.resolver is part of the usBIM ecosystem | ACCA software
Leverage integration with usBIM, the openBIM collaborative platform that accompanies the digital transition of your business
usBIM.resolver general contractor software is part of the usBIM ecosystem.
Learn more
The usBIM applications
Sign in now for free
